Author Topic: arduino+mysql (help)  (Read 2376 times)
Hi I'm new here, and I faced with the problem. I found code witch allows  received sensor data sent to mysql. However, I have a 4 of sensors and want to transfer data to MySQL. Here is my code:
#include <Ethernet.h>
#include <SPI.h>
byte ip[] = { 192, 168, 1, 77 };
byte gw[] = {192,168,1,83};
byte server[] = { 192, 168, 1, 83  }; // Server IP
byte subnet[] = { 255, 255, 255, 0 };
float data = 0;
float tempPin = 2;  // In This case the temperature is taken from pin 2 and sent to a sql server
float temperatura=0;
float sviesPin = 5;
float sviesa = 0;
pinMode(tempPin, INPUT);
Serial.begin(9600);               // Used for serial debugging
Serial.println("Program running...");
 senddata();                                 // Data is sent every 5 seconds
void senddata()
data = analogRead(tempPin);           //Reading analog data
temperatura = ((data*500)/1024);
sviesa = analogRead(sviesPin);
Ethernet.begin(mac, ip, gw, subnet);
Client client(server, 80);
Serial.println();
Serial.println("ATE :)");
delay(1000);                                    //Keeps the connection from freezing
if (client.connect()) {
Serial.println("Connected");
client.print("GET /perkeliam.php?temperatura=");
client.print(temperatura);
Serial.print(temperatura);
client.println(" HTTP/1.1");
client.println("Host: 192.168.1.83");
client.println();
Serial.println();
client.print("GET /perkeliam.php?sviesa=");
Serial.print(sviesa);
client.print(sviesa);
client.println();
Serial.println();
Serial.println("Connection unsuccesfull");
 //stop client
 client.stop();
 while(client.status() != 0)
  delay(5000);
here's my PHP
<html>
<?php
//echo ("update_db.php indicator");
$DATA $_GET['temperatura'];
$DATA1 $_GET['sviesa'];
//Connect to database
$con mysql_connect("localhost""root""");
if(!
$con)
#123;
die('Could not connect: ' .mysql_error());
#125;
mysql_select_db("duomenys"$con);
mysql_query(" INSERT INTO temperatura (id, temp, sviesa, Data) VALUES ('NULL', $DATA$DATA1, NOW())");
mysql_close($con);
</html>
It sends only the first value, while the other disappears who knows where. I would be very grateful for the help. Sorry for my English
« Last Edit: January 13, 2011, 11:52:11 am by MantasRS » Logged
Seattle, WA USA
Seattle, WA USA
You can send all the data in one call:
GET /perkeliam.php?temperatura=valOne[glow]&nextName=valTwo&anotherName=anotherVal&lastName=lastValue[/glow]
Obviously, the GET request requires multiple client.print() statements (8 at least).
Then, the PHP script simply gets the 4 different values from the input string.
Thank you for fast answering. My knowledge is very poor could you show how it would look realized in the code?  :-[
Can i ask a question?
You are using USB connect or ethernetshield?
Because i'm using php with USB connection but i have some trouble to read serial value
Thank a lot
im using ethernet shield
Seattle, WA USA
Seattle, WA USA
client.print("&nextName=");
client.print(valTwo);
client.print("&anotherName=");
client.print(anotherVal);
client.print("&lastName=");
client.print(lastValue);
This assumes, of course, that the variables exist and are valued. And that the names mean something. Neither of these assumptions is true, but the structure is correct.
