Topic: Do you need an external antenna for the Yun Shield wifi? (Read 2748 times) previous topic - next topic
machman2823
So I've looked all over and I can't determine whether the Yun Shield needs an external antenna.  From building FPV Drones, I know that powering a transmitter without an antenna can potentially destroy the transmitter, so I don't want to do anything with it until I can get a solid answer to this question.
Any help would be greatly appreciated.
kantila
The Shield Wifi module is probably 8devices Carambola 2
http://www.8devices.com/products/carambola-2
I haven't seen any warnings or notes about using the module without an external antenna. My Yun Shield has been running for a few days now without apparent issues (stability, heat, connectivity) without an antenna.
- K
Jantje
The yun shield is actually a yun in another format.
The yun runs fine without a antenna.
So do my yun shields.
However I fear drones have a bigger range then wifi. Are you sure this is the correct technology?
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
jpsabo
I have had a Yun Shield running on an Arduino Mega 2560 for about 15 days with no problems. I had the same thought as well. I did quite a bit of searching and it appears that if no external antenna is used, the Yun uses its internal antenna. If an external antenna is used, the antenna with the best signal is selected automatically.
