Topic: extract .hex file from arduino program (Read 13300 times) previous topic - next topic
antoine
Hi, I want to extract the .hex file of my arduino program to use it with Proteus Isis software. Do you know how can I do it?
thanks
Eight
If memory serves, holding shift while clicking the Verify compile button shows you the output of the compile process including the location on disk of the hex file.
antoine
herctrap
and how can we upload that hex file
without using the arduino Ide
with a programmer of course
and what about the fuses?
thanks a lot
robtillaart
Check out the avrdude command. HOld down the shift key while clicking the upload for the syntax. And yes somewhere in your installation there is the avrdude manual. look for the -D option (IIRC)
Rob Tillaart
herctrap
dut
how we can get .asm file from Arduino software?..
it is posible?
dut eden rockes
robtillaart
it is posible?
~\arduino-0021\hardware\tools\avr\bin\avr-objdump.exe
check the -D or -d  option in the manual.
Rob Tillaart
floresta
#8
Jan 20, 2011, 10:02 pm Last Edit: Jan 20, 2011, 10:07 pm by floresta Reason: 1
and what about the fuses?I have successfully switched back and forth between using the Arduino IDE / bootloader and Studio 4 / programmer without changing the fuses.  It's not the best solution and may not work if the op codes are enhanced in the future but currently I assume that the values in the unprogrammed bootloader memory space are being treated as NOPs (no operation) when the processor incorrectly starts its execution there.
Don
