Loading...
Pages: [1]   Go Down
Author Topic: Phidgets ph adapter interfaceing  (Read 2612 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi all,
finally i got the 1130 - pH/ORP Adapter of phidgets (http://www.phidgets.com/products.php?category=20&product_id=1130
and PH elctrode from ebay.
i tired to write the C code for it to but the results isn't correct.\
i bought 3 water bottles (PH 6.8, 7.45, 7.smiley-cool but the result that i get isn't good, according to the formula in the manual guide: http://www.robotshop.com/content/PDF/product-manual-1130.pdf
Code:
const int PHprobe = 1;
int WaterTemp = 18;
float pH1, pH2, pH3;
int i;
for(i = 0;i <= 7;i++) {
pH2 += 0.0178 * analogRead(PHprobe) - 1.889;
  pH3 += 7 - (2.5 - analogRead(PHprobe)/1024) / (0.257179 + 0.000941468 * WaterTemp);
pH1 = analogRead(PHprobe);
       Serial.print(pH1,  DEC);
       Serial.print("\n");
       pH2 = pH2 / 8;
        Serial.print(pH2,  DEC);
        Serial.print("\n");
        pH3 = pH3 / 8;
         Serial.print(pH3,  DEC);
         Serial.print("\n");
       Serial.print("====================================");
       Serial.print("\n");
       delay(10000);
the results i got:
                            pH1    ||    pH2    ||  pH3     ||    Voltage
7.8 water              532          7.58        5.188              2.662
7.45 water             552          7.93        5.188              2.655
6.8 water              499          6.99        5.188              2.428
tnx alot for the helpers...
Logged
Z
Australia
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Anytime I have used pH meters, step #1 was calibrating. If you interpolate between the high pH sensor value and low pH sensor value can you predict what the middle pH sensor value would be? Aka make up your own equation.
With such close pH values in your samples, it is possible the setup is having trouble. It might be worth beginning with detecting pH3 pH10 then going for precision measurements around pH 7
However I would first alter the code to get more consistent readings. I would analog read once each loop, there may be variations between each reading in your loop (i would bet on it). This would cause inconsistent variation between the corrected and uncorrected values.
I would change the code to:
* read the sensor value x 8
* determine the mean sensor value over 8 measurements.
* calculate the pH based on the mean  sensor value
* calculate the temp corrected pH based on the mean sensor value
Also, It might be worth taking more than 8 readings. (say, 80, but only delay 100...?)
The temperature corrected value seems off, your calculation uses 1024 rather than 200.
« Last Edit: January 20, 2011, 06:26:49 pm by zwatts » Logged
Pages: [1]   Go Up
Print
Jump to:
