Topic: 7-Segment Display Wiring and Programming (Read 96270 times) previous topic - next topic
CrossRoads
You need to get a copy of the datasheet
http://focus.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=tpic6b595&fileType=pdf
SRCK clocks the 8 bits into the Input Register one by one.
RCK then clocks all 8 bits together into the Output Register to drive the LED segments.
G/ can be tied low.
SRCLR/ can be tied high (Vcc) if you do not want to clear all the input registers at once.
SER IN is the data to be shifted in
SER OUT is the data to be shifted into the next device in line.
guitarboy667
I read that part, but the Arduino site said that the latch pin needs to be connected to ground:
http://arduino.cc/en/Tutorial/ShiftOut
So is that right and if so, which is the latch pin line?
CrossRoads
You have to look at the specific part being used.
The 74HC595 will die with the higher voltage you need for your multiple-LED/segment display.
The TPIC6B595 has a different pinout & functionality, you will need the 2 clock inputs as I described.  Electrical Engineer, trust me on this one.
guitarboy667
Oh ok, I used the TPIC6B595. So is there a latch pin at all then?
http://www.sparkfun.com/datasheets/IC/TPIC6B595.pdf
Right now I have SER IN, SRCK, and RCK connected to the Arduino.
Vcc and G to 5 volts and all three grounds and SRCLR connected to ground.
CrossRoads
G needs to go to ground, that is the active low output enable.
SRCLR needs to be high, it clears the input register when it is low.
SRCK shifts in the 8 bits.
RCK clocks the 8 bits into the output register to control your segments.
So there is no Latch pin - the functionality is different, you need an edge to clock the register.
guitarboy667
Right, I switched those somehow. The code you mentioned had a latch pin, so I don't think it will work.
So I send in the 8 bits through SRCK? I thought that was what SER IN did. I can try writing some code once I figure out what information each input needs sent.
Sorry this is taking so long. I appreciate your help. I was sent this site:
and I tried to use that but it seems to be about the other shift register configuration that uses a latch pin. Both shift registers are 595s though.
CrossRoads
You'll need something like this:
Code: [Select]
shiftOut(shiftdatapin, shiftclockpin, MSBFIRST, shiftregdata); // puts the bits into the input register
digitalWrite (RCK, LOW);
digitalWrite (RCK, HIGH); // puts the bits into the output register.
where shiftdatapin connects to SER IN,
shiftclockpin connects to SRCK.
MSBFIRST says bit 7 of your data is going out first,
and shiftregdata is your segment data (bit 0-7 representing segments A-G & DP for example).
595 has lots if variations. Need to read the datasheets and wire accordingly.
guitarboy667
Wow that works great! Thanks!
Do you know how I could get the code to interpret numbers into bytes that needs to be sent?
Code: [Select]
int shiftdatapin = 48;
int shiftclockpin = 50;
int RCK = 52;
byte numbers[10] =
 B00111111, // 0
 B00000110, // 1
 B01010011, // 2
 B01001111, // 3
 B01100110, // 4
 B01101101, // 5
 B01111101, // 6
 B00000111, // 7
 B01111111, // 8
 B01101111  // 9
 //set pins to output so you can control the shift register
 pinMode(shiftdatapin, OUTPUT);
 pinMode(shiftclockpin, OUTPUT);
 pinMode(RCK, OUTPUT);
shiftOut(shiftdatapin, shiftclockpin, MSBFIRST, B01111111); // puts the bits into the input register
The above code works, but I'd like to be able to put a variable into the code instead of B01111111.
Would the above code work for multiple digits too?  For example, could I send 1493 to a string of 4 digits of the display and it'd work or do I have to somehow separate 1493 into individual numbers and send them out?
CrossRoads
#38
Jan 19, 2011, 05:11 am Last Edit: Jan 19, 2011, 05:12 am by CrossRoads Reason: 1
Easy question first : 1493. Do you have 4 shift registers connected together, so that the output of one feeds the input of 2, two's output feeds 3's input, etc?
If so, you can just do 4 shiftouts in a row. If not, do 4 shiftouts to the individually controlled registers.  Shiftout is a software feature, pretty similar to:
digitalWrite (pin, bit0);
digitalWrite (clock low);
digitalWrite (clock, high);
//repeat 7  times for bit1, bit2, ...bit7.
You can also do a hardware controlled shiftout that would go faster using SPI, but you have to use specific pins for it. Go do some reading about it.
Code: [Select]
shiftregdata = byte1;
shiftregdata =  byte2;
shiftregdata  = byte3;
shiftregdata  = byte4;
now, making bytex= numbers
  • , maybe something like this:
    shiftregdata[1] = numbers[ones_seconds];
    shiftregdata[2] = numbers[tens_seconds];
    shiftregdata[3] = numbers[ones_hours];
    shiftregdata[4] = numbers[tens_hours];
    and the 4 shifts above could be pulled into a loop? Defined as:
    for (initialization; condition; increment) {
    //statement(s);
    This loop should do 4 shiftouts, fancier than anything I've tried yet:
    Code: [Select]
    //for (x=1 to 4)
    for (x=0;  x<5; x=x+1;){  //maybe x==4, and x++ instead x=x+1?? x=x+1 is clearer (to me). Try it.
    shiftOut(shiftdatapin, shiftclockpin, MSBFIRST, shiftregdata[x]); // load input register
    digitalWrite (RCK, HIGH); // load output register.
    //Serial.writeln shiftregdata[x];  // to make sure
guitarboy667
I have 4 in a row, but the second data input seems to just overwrite the first.
Code: [Select]
int RCK = 52;
int shiftregdata;
byte numbers[10] =
 B00111111, // 0
 B00000110, // 1
 B01010011, // 2
 B01001111, // 3
 B01100110, // 4
 B01101101, // 5
 B01111101, // 6
 B00000111, // 7
 B01111111, // 8
 B01101111  // 9
shiftregdata =  B00000111;
guitarboy667
Code: [Select]
int RCK = 52;
int shiftregdata;
byte numbers[10] =
 B00111111, // 0
 B00000110, // 1
 B01010011, // 2
 B01001111, // 3
 B01100110, // 4
 B01101101, // 5
 B01111101, // 6
 B00000111, // 7
 B01111111, // 8
 B01101111  // 9
shiftregdata =  B11111111;
shiftregdata =  B00000110;
Well actually the first number just shows up on both
guitarboy667
Added a delay and got that sorted out actually.
guitarboy667
Right now the only thing left I have to figure out is this. Say the Arduino does some calculations and comes up with the number (int) 2,590, how would I send that to the display?
Won't I somehow have to separate each place (ones, tens, hundreds, etc.) into a single number and convert that to bytes? How can I convert say 3 into B01001111.
This didn't seem to work:
Code: [Select]
byte numbers[10] =
 B00111111, // 0
 B00000110, // 1
 B01010011, // 2
 B01001111, // 3
 B01100110, // 4
 B01101101, // 5
 B01111101, // 6
 B00000111, // 7
 B01111111, // 8
 B01101111  // 9
I'm also interested in controlling decimal points.
CrossRoads
Where'd you put the delay to make it work?
Decimal point - use the 8th bit to drive the DP.
I do things like this to turn the bit Hi & Low:
Say you have databyte B11111111
To make the 8th bit Low, AND it with 0:
databtye = databute && B01111111
The other bits that are ANDed with 1 are not changed from their original state (0 AND 1 = 0, 1 AND 1 = 1)
To make it back high, OR it with a 1:
databyte = databyte || B10000000
The other bits that are ORed with 0 are not changed (0 OR 0 = 0, 1 OR 1 = 1)
Your other question: I need to know more what a number like 2,593 is.
Are those 4 hex digits?
There are ways to separate it into digits.
For example,  hex data  digit = 2593:
digit0 = digit AND 0x000F  now digit0 = 0003
digit1 = digit >>4 now digit 1 = 0259 (shifted 4  bits away)
digit1 = digit1 AND 0x000F now digit1 = 0009
digit2 = digit1 >>4 now digit2 = 0025
digit2 = digits AND 0x000F now digit2 = 0005
digit3 = digit2 >>4 now digit3 = 0002
Then dataout = numbers[digit0] should give the 7-segment mapping you want for a 3.
So I guess Yes, you have to split it into bytes.
guitarboy667
the 2,593 would be an int(eger) stored in a variable
