Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: 7-Segment Display Wiring and Programming  (Read 25041 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
I get how to control the decimal points, but I just wanted to make sure that when the integer was converted into bytes the decimal was kept.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
I put the delay at the end.  The code I was running didn't have anything else in it, so as soon as it finished sending say 68 it was sending another 8 through that got rid of the 6.
« Last Edit: January 20, 2011, 12:54:03 pm by guitarboy667 » Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Okay, so split it  up & send it out.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Full Member
Arduino rocks
View Profile
How do I split it and how do I keep the decimal?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I presented a way to do that earlier:
"Your other question: I need to know more what a number like 2,593 is.
Are those 4 hex digits?
There are ways to separate it into digits.
For example,  hex data  digit = 2593:
digit0 = digit AND 0x000F  now digit0 = 0003
digit1 = digit >>4 now digit 1 = 0259 (shifted 4  bits away)
digit1 = digit1 AND 0x000F now digit1 = 0009
digit2 = digit1 >>4 now digit2 = 0025
digit2 = digits AND 0x000F now digit2 = 0005
digit3 = digit2 >>4 now digit3 = 0002"
Try this:
digit = 0x2593;
digit0 = digit && 0x000F;  // mask off the upper 12 bits
Serial.print (digito, HEX);
digit1 = digit >>4; // shift off the lower 4 bits
digit1 = digit1 && 0x000F; // mask off the upper 12 bits
Serial.print (digit1, HEX);
digit2 = digit >> 8; // shift off the lower 8 bits
digit2 = digit2 && 0x000F; // mask off the upper 12 bits
Serial.print (digit2, HEX);
digit3 = digit >> 12; // shift off the lower 12 bits
digit3 = digit3 && 0x000F; // mask off the upper 12 bits
Serial.print (digit3, HEX);
I don't know where the decimal point goes, not enough info provided.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Those would be int numbers not hex, but did you provide a conversion from into to hex in the beginning of the code? If so, then that should work.
The thing is I want to display a calculated number stored in a variable.
So say
x= 36.3
or
x=2.58
Ideally I'd like to be able to convert x into something to send to the 7-segment displays.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Non-ideally I'd like to get the decimal between the last 2 digits. (234.5 for example)
Thanks for your help man.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
So what do the "two 7-segment displays of 4 digits each" represent?
Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
