Topic: blinkm addressing problem.. (try it on your blink) (Read 8809 times) previous topic - next topic
hi everyone,
so i am having an issue trying to readdress a blinkM, i've also tried on a MaxM, but i would guess the firmware is the similar to a point.
so, i started with my own bit of code to sort out what i knew and didnt know about i2c, a fair bit - but i can write to the blink's with no problem. i have 3 pots hooked up and can control rgb directly. nothing new, i know, but it was an exercise.
so the next step is to control multiple blinks, independently. i can't get the addresses to stick though.  here is my edited version of the stock code that is in the examples. i could be doing something silly, like sending hex instead of int, or something very strange could be going on... any help would be appreciated.
Code: [Select]
#include "Wire.h"
#include "BlinkM_funcs.h"
byte blinkm_addr = 0x08;
byte blinkm_globaladdr = 0x00;
int temp;
   Serial.print("Setting I2C address...");
   BlinkM_setAddress( blinkm_addr );
   Serial.println(blinkm_addr, HEX);
   Serial.print("Verifying I2C address, sent to 'correct' address...");
   temp = BlinkM_checkAddress( blinkm_addr ); //sent to what it should be
   Serial.print("Verifying I2C address, sent to global address...");
   temp = BlinkM_checkAddress( blinkm_globaladdr );
//sent to global, should return matching
   Serial.println("Did it work?");
   digitalWrite(13, HIGH); // flash Arduino LED for fun
   digitalWrite(13, LOW);
Thanks -- Jon   :)
...as continuation, i looked inside the blinkM_funcs.h and uncommented some of the debug messages, no change, still having an address problem.
here is the response, sorry it a bit of a mess
Code: [Select]
Setting I2C address...8
Verifying I2C address, sent to 'correct' address...received addr: 0x80
Verifying I2C address, sent to global address...No response, that's not good
Did it work?
and as a followup to my own post, hope this helps someone else...
haven't tried it yet, i'll give some feedback to see if it helps.
fail... :-(
i have 1.0c blinkm's   anyone?
Have you tried using the "BlinkMTester" Arduino sketch that comes as part of the BlinkM Examples bundle?  It has the ability to let you re-address BlinkMs and I use it all the time.
The home of the BlinkM Examples bundle lives here:
You can download the examples as a zip file here:
Or you can examine the source code to BlinkMTester here:
Let me know if BlinkMTester works.  If it doesn't, but otherwise the BlinkM appears to function, then you may have a bad BlinkM.  We can arrange an exchange for you then.
HI Todd, thanks for the reply. The example does work, but i am getting strange results when i request the address. here is the output below.
Code: [Select]
Looking for a BlinkM: Device found at addr 2
Resetting address to default 9:
Setting address to: 1
Address: -1
what do you think? is this normal, or something a bit strange?  i can complete my project, but i think it's odd that the firmware updater doesn't work, nor when requesting an address, to get something meaningful back.
and... the last one...
it works, but i am really confused at "how" to send the addresses.
if the default address is 0x09, i would expect to change the address in a similar format - like 0x11, or 0x34. but if i write the destination address in that format - no luck, it doesn't work - if i write as plain 11 or 34, it works, so what is the  " "  or ' ' or 0x  for??
byte blinkm1 = 11;  //default is 0x09, re-addressed
byte blinkm2 = 34;
thanks anyone for your help...
