Topic: reading pulse from rotary dialer (Read 2132 times) previous topic - next topic
junetic
hi,
I was trying to read the number of on/off pulses from a rotary dialer. I found some script from Tom Igoe, and it almost works...as I can count the number of reads from serial to corresponds with the number I dial on the rotary dialer. I have no idea how this code is exactly working...can someone help?
Pulse_in
by Tom Igoe
Reads the values from a Memsic 2125 2-axis accelerometer.
In order to do so, uses a function called pulseIn, which reads
the width of a pulse on a pin.
Created 11 Feb. 2006
int ledPin = 13; // choose the pin for the LED
int inPin = 7;   // choose the input pin (for a pushbutton)
int val = 0;     // variable for reading the pin status
int p;
// Function prototypes:
int pulseIn(int inPin, int desiredState);
 beginSerial(9600);
 pinMode(ledPin, OUTPUT);  // declare LED as output
 pinMode(inPin, INPUT);    // declare pushbutton as input
 printString("Starting\r\n");
 p = pulseIn(inPin, HIGH);    // read pulsewidth
 printString("got a roll\n");
 printInteger(p);            // print p value
 printString("\r\n");           // print return character and newline character
val = digitalRead(inPin);  // read input value
 if (val == HIGH) {         // check if the input is HIGH
   digitalWrite(ledPin, HIGH);  // turn LED on
   digitalWrite(ledPin, LOW);  // turn LED off
 pulseIn function.  reads the width of a pulse on a pin.
Takes a pin number and the desired state, HIGH or LOW.
Watches for the pin to change from the non-desired state to
the desired state, then counts loops until the pin changes
back again.
int pulseIn(int inPin, int desiredState) {
 int count = 0;        // local counter
 int finalCount = 0;   // final number of loops the pulse takes
 int pinState;         // state of the pin you're watching
 int lastState = desiredState;   // place to store the previous state of the pin
 int difference = 0;
 while (finalCount <= 0) {
   pinState = digitalRead(inPin);
   difference = pinState - lastState;
   if ((difference > 0) &&(desiredState == HIGH)) {
     // start counting pulses
     count++;
   if ((difference < 0) &&(desiredState == HIGH)) {
     // stop counting pulses
     finalCount = count;
     count = 0;
   if ((difference < 0) &&(desiredState == LOW)) {
     count++;
   if ((difference > 0) &&(desiredState == LOW)) {
     finalCount = count;
     count = 0;
   // save the state of the pin as the old state,
   // so we can get a new state to compare it to:
   lastState = pinState;
 // you're done.  Return the final count:
 return finalCount;
http://www.tigoe.net/pcomp/code/archives/arduino/000748.shtml
