Loading...
Pages: [1]   Go Down
Author Topic: making a library using timer.c  (Read 658 times)
Poitiers (France)
Offline Offline
Full Member
Ca va j'vais le faire !
View Profile
WWW
Hello,
First, please excuse me for my poor english.
I'm trying to make a clock library using timer.c.
By modify wiring.c & .h I have made a clock with Arduino : http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1151887411. Now, I want to do it better by writing a library to generate precise delays using interrupts (at min vector 7). This library named "TicTac", I think, could be very useful for many users and projects.
HELP !  :'(
First I'm try to do this :
Code:
#undef PI
#include "timer.h"
void TicTac::Start()
  // arrêt des fonctions PWM
  timer1PWMOff();
  // réglage du pré-diviseur de fréquence
  // TCNT1 sera incrémenté tous les 1024 tics
  // de l'horloge du micro-controlleur
  timer1SetPrescaler(TIMER_CLK_DIV1024);
  // liaison de l'interruption TIMER1OUTCOMPAREA_INT
  // avec la fonction TicTac
  timerAttach(TIMER1OUTCOMPAREA_INT, Bip);
The compiler respond me :
lib\targets\libraries\TicTac\TicTac.o: In function `TicTac::Start()':
/cygdrive/e/Arduino/arduino-0004-win/arduino-0004/lib\targets\libraries\TicTac\TicTac.cpp:77: undefined reference to `timer1PWMOff()'
/cygdrive/e/Arduino/arduino-0004-win/arduino-0004/lib\targets\libraries\TicTac\TicTac.cpp:93: undefined reference to `timer1SetPrescaler(unsigned char)'
/cygdrive/e/Arduino/arduino-0004-win/arduino-0004/lib\targets\libraries\TicTac\TicTac.cpp:98: undefined reference to `timerAttach(unsigned char, void (*)())'
I think that the linker does not found the timer.o.
In second time I 'm trying to do something like that :
Replacing all the timer.c functions by mine's, including the ISR function.
Code:
ISR(SIG_OUTPUT_COMPARE1B)
  // timer1PWMOff();
      // turn off timer1 PWM mode
      cbi(TCCR1A,PWM11);
      cbi(TCCR1A,PWM10);
      // turn off channel A (OC1A) PWM output
      // set OC1A (OutputCompare action) to none
      cbi(TCCR1A,COM1A1);
      cbi(TCCR1A,COM1A0);
      // turn off channel B (OC1B) PWM output
      // set OC1B (OutputCompare action) to none
      cbi(TCCR1A,COM1B1);
      cbi(TCCR1A,COM1B0);
  // timer1SetPrescaler(TIMER_CLK_DIV1024);
      outb(TCCR1B, (inb(TCCR1B) & ~TIMER_PRESCALE_MASK) | TIMER_CLK_DIV1024);
  // timerAttach(TIMER1OUTCOMPAREA_INT, Bip);
C:\DOCUME~1\Benoit\LOCALS~1\Temp\build28293.tmp\timer.c.o: In function `__vector_7':
E:\Arduino\arduino-0004-win\arduino-0004\lib\targets\arduino\timer.c:458: multiple definition of `__vector_7'
lib\targets\libraries\TicTac\TicTac.o:/cygdrive/e/Arduino/arduino-0004-win/arduino-0004/lib\targets\libraries\TicTac\TicTac.cpp:54: first defined here
/cygdrive/e/Arduino/arduino-0004-win/arduino-0004/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/bin/ld: Warning: size of symbol `__vector_7' changed from 148 in lib\targets\libraries\TicTac\TicTac.o to 90 in C:\DOCUME~1\Benoit\LOCALS~1\Temp\build28293.tmp\timer.c.o
Ok, that's right,  `__vector_7' was defined in timer.c.
How can I do ? Is somebody have any idea ?
« Last Edit: July 08, 2006, 05:35:14 am by Benoit » Logged
Cordialement,
Benoît ROUSSEAU
Pages: [1]   Go Up
Print
Jump to:
