Author Topic: Array?  (Read 892 times)
Newcastle upon Tyne
Hello,
Does the Arduino language cater for arrays?
i'm wanting to use three ultraound sensors with one of my i/o boards; is it possible to do something like this:
digitalWrite([1,2,3], LOW);
delayMicroseconds(2);
digitalWrite([1,2,3], HIGH);
delayMicroseconds(5);
(which is how i'd use an array in SuperCollider)
insead of declaring a variable and doing this:
int ultraSoundSignal = 7; // Ultrasound signal pin
digitalWrite(ultraSoundSignal, LOW);
digitalWrite(ultraSoundSignal, HIGH);
digitalWrite(ultraSoundSignal, LOW); // Holdoff
or is there some other way of using an array or list, or do I have to do the above for each pin I am using?
cheers,
will schrimshaw.
Poitiers (France)
Ca va j'vais le faire !
Hello Will,
The Arduino language define digitalWrite function as :
void digitalWrite(int pin, int val)
      if (digitalPinToPort(pin) != NOT_A_PIN) {
            // If the pin that support PWM output, we need to turn it off
            // before doing a digital write.
            if (analogOutPinToBit(pin) == 1)
                  timer1PWMAOff();
            if (analogOutPinToBit(pin) == 2)
                  timer1PWMBOff();
            if (analogOutPinToBit(pin) == 3)
                  timer2PWMOff();
            if (val == LOW)
                  cbi(_SFR_IO8(port_to_output[digitalPinToPort(pin)]),
                        digitalPinToBit(pin));
                  sbi(_SFR_IO8(port_to_output[digitalPinToPort(pin)]),
So you cannot use an array in place of int type definition of the pin parameter of the digitalWrite function.
But I think you can make your own definition of a new function wich can use an int array as parameter.
Benoît ROUSSEAU.
Cordialement,
Benoît ROUSSEAU
Poitiers (France)
Hello Will,
To complete response to you :
In article http://www.arduino.cc/en/Tutorial/LCD8Bits you can see something interesting for you.
int DB[] = {3, 4, 5, 6, 7, 8, 9, 10};
int Enable = 2;
void LcdCommandWrite(int value) {
 // poll all the pins
 int i = 0;
 for (i=DB[0]; i <= DI; i++) {
   digitalWrite(i,value & 01);
   value >>= 1;
 digitalWrite(Enable,LOW);
 delayMicroseconds(1);
 // send a pulse to enable
 digitalWrite(Enable,HIGH);
 delayMicroseconds(1);  // pause 1 ms according to datasheet
In particular, see
and
 int i = 0;
   value >>= 1;
Best regards,
Benoît ROUSSEAU
Cordialement,
Benoît ROUSSEAU
Newcastle upon Tyne
Hi Benoît,
Thanks for digging that out, I'll give it a shot sometime this week. However....
Only just had time to sit down and start figuring out how I might do this (before reading your message).
I have been doubling up some code that worked with one sensor, the data I am getting back seems to be the combined value of the two sensors wired to digital pins 6 and 7, which I am guessing is something to do with this bit:
serialWrite('A'); // Example identifier for the sensor
printInteger(aultrasoundValue);
printInteger(bultrasoundValue);
serialWrite(10);
I was wondering how I might go about sepparating the streams being received on pins 6 and 7? sending some kind of array of the two values rather than their combined value.
all the code is pasted below incase you have time to take a look, I am sure there will be a million things wrong as I'm rather new to arduino.
cheers.
// Ultrasound Sensors
int aultraSoundSignal = 6; // US 1
int bultraSoundSignal = 7; // US 2
int aval = 0;
int bval = 0;
int aultrasoundValue = 0; //US1 Value
int bultrasoundValue = 0; //US2 Value
int atimecount = 0; // Echo counter
int btimecount = 0;
int ledPin = 13; // LED connected to digital pin 13
  beginSerial(9600);                  // Sets the baud rate to 9600
  pinMode(ledPin, OUTPUT);            // Sets the digital pin as output
 atimecount = 0;
 btimecount = 0;
 aval = 0;
 bval = 0;
 pinMode(aultraSoundSignal, OUTPUT); // Switch signalpin to output
 pinMode(bultraSoundSignal, OUTPUT);
/* Send low-high-low pulse to activate the trigger pulse of the sensor
digitalWrite(aultraSoundSignal, LOW); // Send low pulse
digitalWrite(bultraSoundSignal, LOW);
delayMicroseconds(2); // Wait for 2 microsecond
digitalWrite(aultraSoundSignal, HIGH); // Send high pulse
digitalWrite(bultraSoundSignal, HIGH);
delayMicroseconds(5); // Wait for 5 microseconds
digitalWrite(aultraSoundSignal, LOW); // Holdoff
/* Listening for echo pulse
pinMode(aultraSoundSignal, INPUT); // Switch signalpin to input
aval = digitalRead(aultraSoundSignal); // Append signal value to val
pinMode(bultraSoundSignal, INPUT); // Switch signalpin to input
bval = digitalRead(bultraSoundSignal);
while(aval == LOW) { // Loop until pin reads a high value
while(bval == LOW) { // Loop until pin reads a high value
while(aval == HIGH) { // Loop until pin reads a high value
  atimecount = atimecount +1;            // Count echo pulse time
  while(bval == HIGH) { // Loop until pin reads a high value
  btimecount = btimecount +1;            // Count echo pulse time
/* Writing out values to the serial port
aultrasoundValue = atimecount; // Append echo pulse time to ultrasoundValue
bultrasoundValue = btimecount;
serialWrite(10);
/* Lite up LED if any value is passed by the echo pulse
if(atimecount+btimecount > 0){
  digitalWrite(ledPin, HIGH);
/* Delay of program
delay(100);
Poitiers (France)
Good evening Will,
Ok, I think that I start to understand your problem.
It's too late for me to respond ZZzzz ! smiley
But I have a question: do you have to read the two sensors simultaneously? Some 10's milliseconds between the read of the two sensors could be acceptable for your project?
At the first read,
- I think that an array doesn't change anything ;
- your code could have some problems if B sensor take a pulse before the A sensor ;
- using external interrupt could be a best solution for you ;
- you can reduce your code and optimize it by replacing :
by
#define aultraSoundSignal 6
#define bultraSoundSignal 7
note that there no ; at the end of the line.
I'll take a break tomorow to make a new post about this.
Please excuse my poor english.
Best regards,
Benoît ROUSSEAU
« Last Edit: July 11, 2006, 07:00:48 pm by Benoit » Logged
Cordialement,
Benoît ROUSSEAU
Newcastle upon Tyne
Hi Benoît,
A delay of that length will be no problem at all. I had thought that looping the routine and alternating the active pins might be a way around the problem but it was a little late to start working on that last night.
I'll try a few things out this evening.
cheers,
will schrimshaw.
Poitiers (France)
Hi Will,
The next code was not test or compiled, take care... it's just an example :
unsigned long ASensorDelay;
unsigned long BSensorDelay;
unsigned long readSensor (int sensorpin)
      // Setup
      int _register = port_to_input[digital_pin_to_port[sensorpin].port]; // register is a reserve word so _ before
      int bit = digital_pin_to_port[sensorpin].bit;
      int mask = 1 << bit;
      unsigned long pulsewidth = 0;
      // Send low-high-low pulse to activate the trigger pulse of the sensor
      pinMode (sensorpin, OUTPUT); // sensorpin to output
      digitalWrite (sensorpin, LOW); // Send low pulse
      delayMicroseconds (2); // Wait for 2 microsecond
      digitalWrite (sensorpin, HIGH); // Send high pulse
      delayMicroseconds (5); // Wait for 5 microseconds
      digitalWrite (sensorpin, LOW); // Holdoff
      // Listening for echo pulse
      pinMode (sensorpin, INPUT); // sensorpin to input
      while ((_SFR_IO8(_register) & mask) == LOW); // wait for the pulse to start
      while ((_SFR_IO8(_register) & mask) == HIGH) // wait for the pulse to stop
            pulsewidth++;
      return pulsewidth * 20UL / 23UL;
      ASensorDelay = readSensor (aultraSoundSignal);
      BSensorDelay = readSensor (bultraSoundSignal);
      // Writing out values to the serial port
      serialWrite('A'); printInteger(ASensorDelay); serialWrite(10);
      serialWrite('B'); printInteger(BSensorDelay); serialWrite(10);
      // Lite up LED if any value is passed by the echo pulse
      if(ASensorDelay + BSensorDelay > 0)
      // Delay of program
      delay(100);
I have made a function to read pulse inspired by pulseIn code in wiring.c file :
/* Measures the length (in microseconds) of a pulse on the pin; state is HIGH
 * or LOW, the type of pulse to measure.  Works on pulses from 10 microseconds
 * to 3 minutes in length, but must be called at least N microseconds before
 * the start of the pulse. */
unsigned long pulseIn(int pin, int state)
      // cache the port and bit of the pin in order to speed up the
      // pulse width measuring loop and achieve finer resolution.  calling
      // digitalWrite() instead yields much coarser resolution.
      int r = port_to_input[digitalPinToPort(pin)];
      int bit = digitalPinToBit(pin);
      unsigned long width = 0;
      // compute the desired bit pattern for the port reading (e.g. set or
      // clear the bit corresponding to the pin being read).  the !!state
      // ensures that the function treats any non-zero value of state as HIGH.
      state = (!!state) << bit;
      while ((_SFR_IO8(r) & mask) != state)
      while ((_SFR_IO8(r) & mask) == state)
            width++;
      // convert the reading to microseconds.  the slower the CPU speed, the
      // proportionally fewer iterations of the loop will occur (e.g. a
      // 4 MHz clock will yield a width that is one-fourth of that read with
      // a 16 MHz clock).  each loop was empirically determined to take
      // approximately 23/20 of a microsecond with a 16 MHz clock.
      return width * (16000000UL / F_CPU) * 20 / 23;
Something wrong with my code is that you have to have pulse (LOW->HIGH->LOW) return from each sensor to work. Without a pulse, "while" loops are infinite.
If you are uncertain of sensor pulse return, you have to add a counter to check "overload" and a break to exit each while loop. But, you will have minus precision on pulse width measure.
Best regards,
Benoît ROUSSEAU
Cordialement,
Benoît ROUSSEAU
Poitiers (France)
Hello will,
  Your code seems to be inspired by http://webzone.k3.mah.se/projects/arduino-workshop/projects/arduino_meets_processing/instructions/ultrasound.html. So, it works ! And i'm now certain that you have a return pulse each time a sensor is activated. My code, will be ok.
  Tell me if it work.
Benoît ROUSSEAU
« Last Edit: July 13, 2006, 05:35:37 pm by Benoit » Logged
Cordialement,
Benoît ROUSSEAU
Newcastle upon Tyne
yeah, got it from the lovely arduino playground, just trying to get it to work for multiple sensors on one board. haven't quite got there yet though..... i'll let you know when it works.
will.
