Topic: serial read (Read 906 times) previous topic - next topic
lisarosen
hello,
i interfaced two HEF4794B - works fine as standalone with the code example "shift out".
But now I would like to send over PD a word (highbyte, lowbyte) to the serial port and store the incoming hbyte and the lbyte again in a word, to control the 16 Leds at the same time....
(with just one driver and only 8 leds it works fine:)
  // send data only when you receive data:
     if (Serial.available() > 0) {
           // read the incoming byte:
           dato = Serial.read();
   for (count = 0; count < 8; count++) {
   digitalWrite(data, dato & 01);
   //serialWrite((dato & 01) + 48);
   dato>>=1;
   if (count == 7){
   digitalWrite(oe, LOW);
   digitalWrite(strob, HIGH);
   PulseClock();
    digitalWrite(oe, HIGH);
 delayMicroseconds(10);
 digitalWrite(strob, LOW);
 delay(10); // waits for a moment
but with the word I will have a memory problem with the int - so i'm wondering if i can use (in arduino) as well unsignded int (uint)?
by including which library? (pascal stangs avr/io?)
or do i have to use arrays to read over the serial port more than one incoming byte? (like described in the serialComm-string example)....but how do I get then again a "word" out of this single chars?
thanks a lot for any help, as you can see, i'm a newbeee;)
lisarosen
lisarosen
hello again, this is a self-answer;
yes:)) I can use instead of an int a unsigned, as I found in the keywords.txt in the libfolder of arduino...
reading more than one byte is no problem, because they get buffered....???
and this modified code (originally shift_out) works now perfect with pd or max, sending simultaneously a high- and a lowbyte, whenever i like to change the lightpattern of the 16 leds;)
int data = 9;
int strob = 8;
int clock = 10;
int oe = 11;
int count = 0;
int dato = 0;
int dato2 = 0;
unsigned datostored = 0;
unsigned datoo = 0;
 beginSerial(9600);
 pinMode(data, OUTPUT);
 pinMode(clock, OUTPUT);
 pinMode(strob, OUTPUT);
 pinMode(oe, OUTPUT);
void PulseClock(void) {
   digitalWrite(clock, LOW);
   delayMicroseconds(2);
   digitalWrite(clock, HIGH);
   delayMicroseconds(5);
               dato2 = Serial.read();
       else {datoo = datostored;
   datoo = (dato * 256) + dato2;
   for (count = 0; count < 16; count++) {
   digitalWrite(data, datoo & 01);
   datoo>>=1;
   if (count == 15){
   datostored = datoo;
   PulseClock();
