Loading...
Pages: [1]   Go Down
Author Topic: Small syntax question  (Read 293 times)
0
Offline Offline
God Member
View Profile
Hey guys,
Hoping someone could help with this small bit of code. I mad a small sketch to light a LED connected the pin which the user selects over the serial connection, eg type 13 to turn on the LED on pin 13, 07 to turn on LED on pin 7 etc...
 I heavily used the code from Gian Pablo Villamil (username gpvillamil) posted here: http:// http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1160543432
Here's my code
Code:
byte incomingByte ;
int LEDpin;
  if (Serial.available()) {         // if serial data waiting
    digitalWrite(LEDpin,LOW);       // if so, turn off previously lit LED
    LEDpin = 0;                     // reset pin variable
     for (int i = 0; i <=1; i++) {  // for the first two bytes (i.e. 0 and 1)
       incomingByte = Serial.read();  // read byte
       Serial.println(incomingByte,DEC);   // print what was read
       LEDpin = LEDpin * 10 + (incomingByte - 48);  // assemble full 2-digit integer
     Serial.print("Lighting up LED #");   // Display which LED will be lit
     Serial.println(LEDpin);
     digitalWrite(LEDpin,HIGH);     // Light up LED
    while (Serial.available()) {
     incomingByte = Serial.read(); // clear the buffer
It all works really well, but here's my question. If I comment out the line
it doesn't work anymore....
What does this line do besides print the byte values out to screen? Does it somehow change the type of incomingByte?
Thanks for your help.
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
The issue is a bit subtle.  Basically, the call to Serial.println() takes long enough for the second byte of serial data to arrive.  The check
Code:
is true as soon as a single byte of data is available; if you then try to read two bytes in succession, the second one will be -1 because no real data is available.  You could try changing the test to:
Code:
if (Serial.available() >= 2)
or replacing the Serial.println() with a delay.
Logged
0
Offline Offline
God Member
View Profile
Code:
That did it - awesome, thanks heaps.
If I could make a suggestion, it would be awesome if there was an example simmilar to this in function. As a newcomer to programming, especially serial communications, it took me ages to work out how to read more than the first byte, and I don't think I ever would have got the process of converting the bytes into a multi-digit integer without the code I linked to. Anyways just my thoughts, it may have been obvious to everyone else.
Logged
Pages: [1]   Go Up
Print
Jump to:
