Topic: modify setup() from a class (Read 928 times) previous topic - next topic
Gabe462
I'm thinking about making a class that automates setting up & reading from buttons. Would it be possible to set my pinModes (which & how many pins) dynamically? Can I modify setup() from a class?
Gabe
admin
you can use pinmode anywhere in your code... you dont need to modify setup to do that
or make a class that has a method that gets executed in setup() and you can make some last nanosecond changes to the code
massimo
CosineKitty
I think newcomers to Arduino will find it quite helpful and revealing to study the startup code in:
   lib/targets/arduino/wiring.c
For example, if you look at main(), you see a bunch of hardware initialization stuff, and at the very end you see:
   setup();
   for (;;)
       loop();
Then it becomes very apparent that there is nothing special about what you can do in setup() vs loop().
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
