Topic: button debouncing for arduino (Read 937 times) previous topic - next topic
Gabe462
I found this bit of code:
Code: [Select]
boolean DebounceSwitch2() {
     int State = 0;
     State=(State<<1) | !RawKeyPressed() | 0xe000;
     if (State==0x000)
           return true;
     return false;
I'm trying to "port" this to Arduino. I'm pretty sure that RawKeyPressed() would be the same as digitalRead() (for my purposes), but  exactly what does the whole line mean?
Code: [Select]
Gabe
mellis
AFAICT, that code doesn't work (it will always return false), and even if it did, it seems much too clever for what it's trying to do.
I just posted a new example on the tutorial page: http://www.arduino.cc/en/Tutorial/Switch
It uses a pushbutton as a switch to toggle an LED on and off, and debounces the switch input.  Does it help?
Gabe462
I ended up doing almost the exact thing as you:
Code: [Select]
 newState = digitalRead(inPin);
 if ( (newState != prevState) && (timer + bounceTime < millis()) ){
   timer = millis();    //record time of output
   Serial.print((inPin*10)+newState);
 prevState = newState;
Works great so far with my cheap, cheap button!
Gabe
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
