Topic: Assembly language? (Read 922 times) previous topic - next topic
jwinch
Can the Arduino be programmed in assembly language and have the program loaded with the bootloader, or does it expect a sketch written in Wiring? If it's possible, will I gain significantly in speed and reduction of program size by doing that?
admin
if you compile your assembler code into an hex file you can upload it with uisp or any software that supports the stk500 protocol
the serial speed during upload is 19200
you can expect a gain in speed and and size now the issue is : is it worth going through the pain of learning assembler for what you're going to gain?
massimo
jwinch
Good point.
It's nice to know it's possible, in any case.
Thanks for the quick response.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
