Topic: printing BYTE (8bit) to serial (Read 3424 times) previous topic - next topic
lenox
When I use print.serial(data, BYTE), data has to be smaller than 127 (7 bits)
Can I send a 8bits data using serial port?
Thanks in advance
CosineKitty
As far as I can tell (without my hardware right now, but looking at runtime code), I see no reason why Serial.print(x,BYTE) should limit you to 7 bits... 8 bits should work just fine.
lenox
Quote
I tried to use Serial.print(x, BYTE) with x>127 and I got 63 in the PC port (?)  :'(
By code, it's possible to convert a 8bit value in two 7bit values but It would easier send a 8bit value.
byte x=150, x0, x1;
x0 = x & 127;
x1 = (x >>7) & 1;
Serial.print(x0, BYTE);
Serial.print(x1, BYTE);
I would like to send a byte without making this conversion.
llemarie
Is byte signed ? Can you try "unsigned byte x" ?
lenox
Quote
ops it doesn't work  :-/. I can't define a unsigned byte but:
unsigned char x = 200;
Serial.print(x, BYTE);
prints 63
llemarie
#5
Jan 11, 2007, 01:55 pm Last Edit: Jan 11, 2007, 01:55 pm by llemarie Reason: 1
How about "unsigned int" ? (as a test only).
lenox
Quote
(testing  :-?)
   unsigned int v = 200;
   Serial.print(v, BYTE);
I get 63  :'(  ;)
llemarie
Ok, next suspect : the PC software.
What application do you use to read from the serial port ?
mellis
Sending 8-bit data works for me, so I don't think it's broken in general.  What's your Arduino code look like?  How are you reading it on the PC?
Here's the Processing code I'm using to dump the data I get from the serial port:
Code: [Select]
import processing.serial.*;
Serial port;
 port = new Serial(this, Serial.list()[0], 9600);
void draw()
 while (port.available() > 0) {
   int val = port.read();
   println(((char) val) + " " + str(val));
lenox
I have found the problem. In VB.net I was using SerialPort.ReadExisting(). It returns a string converting any value greater than 127 to 63.
Code: [Select]
Dim encoding As New System.Text.ASCIIEncoding, data() as Byte
       data = encoding.GetBytes(SerialPort.ReadExisting())
Using SerialPort.ReadBuffer with a byte array is a possible solution.
Thanks.
