Topic: how do I build a simple theremin like device? (Read 2188 times) previous topic - next topic
madskoser
Hi..
I'm trying to build a simple Theremin like thing and has tryed to so by building a capasitor but I have failed.
I tryed this but it didn't work..
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1171076259
Can anyone help me on how to do such a thing that reacts on your body without one touching it - Don't need it to play music just get the signals in..
I'm new to Arduino and code..
Thank you for your time
//Mads
Cheater
Just electromagnetic fields. :)
Sticking your hand near it alters the field and the wire picks it up.
madskoser
Yes I know it uses the electromagnetic fields but how is the circuit made? I'm a newbie and is quite unsure how to do these kind of things...
MikMo
Use a LDR (Light Dependent Resistor) hooked up to an analog input and use the code floating around for making a sound with a frequency depending on the reading of the LDR. Use your hand to allow more or less light to reach the LDR. This gives you the frequency part of an Theremin. The volume control is not that easy :-)
MikMo
.....or look here:
http://www.freeduino.org/#index
under T
for a connect the dots solution
