Author Topic: Help: serial portname  (Read 374 times)
Please help me, help me.
I have an Diecimila Board- usb. I am using one pushbutton and I want to see the graphic in processing. I went to this site:
http://webzone.k3.mah.se/projects/arduino-workshop/projects/arduino_meets_processing/instructions/pushbutton.html
and everything is working fine on my arduino board.
In processing, I changed the portname to
String portname = "/dev/tty.usbserial-A4001mmw";
which is what i am using in arduino...
but there is this error : gnu.io.PortInUseException: Unknown Application
at gnu.io.CommPortIdentifier.open(CommPortIdentifier.java:
354)            What is it? please help! ::
Thanks. Alisha
« Last Edit: November 03, 2007, 08:38:05 pm by Alisha » Logged
You can only open the port once. If you want to open it in processing, make sure the serial monitor is closed in the arduino IDE.
Forum Administrator
Cambridge, MA
You might also need to run the macosx_setup.command.  See the Processing serial library page for more troubleshooting suggestions: http://processing.org/reference/libraries/serial/
Thanks a lot for your help!... Well, it's still not working at all... no idea why. The serial monitor in arduino was  closed.. Well, I will look at the Processing's link right now. Best-Alisha
Thanks a Lot. smiley-grin
IT IS WORKING!  YOUPPI! the answer was on the processing's Link.
Many thanks.
Alisha 8-)
« Last Edit: November 06, 2007, 07:17:21 am by Alisha » Logged
