Pages: [1] 2   Go Down
Author Topic: Random() Maximum  (Read 691 times)
shrz
Hello there!
I need to create by random really large numbers.
Does the random() function whose type is set as "long", return numbers in the range of long?
between 0 and 2,147,483,647?
when i try to check it by printing the value over serial, it returns always 16807.
any suggestions?
shrz
mh.
im not shure yet.
i thought about the serial.
What is the maximum value i can transmit over serial?
is it the "int" range?
if it is so, how can i send values of the size of "long" over the serial?
(perhaps i should start another topic for that)
woo
« Last Edit: July 14, 2007, 07:02:36 am by woo_oow » Logged
what does your random() call look like?
Integer constants that you want to be of type long need an "L" at the end, e.g.  i = random(2000000L);
-j
shrz
at the moment it looks like:
long x = random(1576800000);
(actually its the amount of seconds of 50 years)
so it should look like: long x = random(1576800000L);?
thanks
w
that's correct.
-j
shrz
Thanks!
this very good to know.
w
« Last Edit: July 14, 2007, 01:36:03 pm by woo_oow » Logged
shrz
There is still a problem:
over the serial i get only values until 5 digits.
for evaluation i used this code:
long x;
void setup(){
   void loop(){
     x=random(1576800000L);
     Serial.println (x);
     delay(100);
it returns values until 32 thousand something.
i dont need the serial thing, but i want to be shure if the random numbers are
created throughout the entire range.
is it just a serial problem?
w
Forum Administrator
Cambridge, MA
Whoops, looks like you found a bug in the core.  We're calling the wrong AVR function, so you'll only get numbers from 0 to 32,767.  You could try calling random() twice and putting the number together, e.g.:
(random(32768) << 15) + random(32768);
shrz
Thanks for your answer!
this could be a solution. I'll try it.
best
w
Sweden
Arduino really rocks
Did you solve it?
By the way, Mellis solution doesn't really get up to your needs. We need one more bit:
(random(1) << 30) + (random(32768) << 15) + random(32768);
If anyone is intrested in a deeper explanation, here is my late-night go:
The random() function can random a highest number of 32,767 which would be it returns 15 bits of random data, so in order to get a larger number we need to connect two or more of those 15 bit chunks.
What we are doing here: (random(32768) << 15) is simply that we push randomed bits 15 bits forward on the variable:
00000000 00000000 0xxxxxxx xxxxxxxx gets into:
                               <----15 steps
00xxxxxx xxxxxxxx x0000000 00000000
Then we add with the next chunk of random data:
00xxxxxx xxxxxxxx x0000000 00000000 +
00000000 00000000 0xxxxxxx xxxxxxxx =
00xxxxxx xxxxxxxx xxxxxxxx xxxxxxxx
Oh, i noticed now that your maximum random number doesn't follow any 2^x number... ok, lets see...
We need to find the largest exponentation in the number:
1 576 800 000 - 1 073 741 824 = 503 058 176
Now we do the same with our result: 503 058 176
503 058 176 - 268 435 456 = 234 622 720
234 622 720 - 134 217 728 = 100 404 992
Oh heck,  i am too tired, just look up which bits in 1 576 800 000 are 1 and make one random(2^x) for each of them where x is the position of the bit (fir example if first bit (bit numer 0) is true, max random is 2 ^ 0 = 1. If the maximum gets over 32 767 just split together like i explained above.
Goodnight!
shrz
Thanks man,
you're right, like this it should generate numbers throughout the field i need, thats great.
i'll try this soon. (at the moment i'm in shanghai, for visiting a friend - its the ultimate electronic parts paradise, you find everything you ever dreamed of!!!)
w
Daniel
Guest
is it better than this? I was in Seoul a month ago... They have whole malls full of IC's..
http://www.flickr.com/photos/electromarketman/sets/72157601136408488/
Sweden
I am so going to Seoul! Just have to persuade my family that they want to go there aswell.
shrz
Its really great to be at places like this!
Daniel, the pictures of Seoul are looking like the Malls in Shanghai. Fantastic.
@ Mellis: in Arduino 0009 is there still a Bug in Random()?
w
Forum Administrator
Cambridge, MA
Yes, sorry, I didn't have a chance to fix it.  Don't worry it's still on the list, hopefully I'll get to it in 0010.
Pages: [1] 2   Go Up
