Topic: Does this code look right? (Read 718 times) previous topic - next topic
acidhax
May 29, 2008, 08:49 pm Last Edit: May 29, 2008, 08:55 pm by acidhax Reason: 1
How does this code look? Its supposed to run multiple PIEZO's and send the data to my serial program.
//VARIABLES
const int numOfAnalogs = 3; //Change the integer to incorporate the amount of analog inputs you use.
int       midiChannel        = 9;
int       outPin             = 13;       // the number of the output pin, main LED
int       analogSmooth       = 2;        // Amount of change needed to send control change...
int       lastAnalogArray[numOfAnalogs];
int       reading[numOfAnalogs];
//END OF VARIABLES
 for (int i = 0; i<numOfAnalogs; i++) {
   reading = analogRead(i)/8; // change 0-1024 into 0-127
   if (abs(reading-lastAnalogArray) > analogSmooth) {
     lastAnalogArray = reading;
     sendToSerial(i,reading);
void sendToSerial(byte pin, byte velocity) {
 digitalWrite(outPin,HIGH);  // indicate we're sending MIDI data
 Serial.print(pin, BYTE);
 Serial.print(velocity, BYTE);
 digitalWrite(outPin,LOW);  // indicate we're sending MIDI data
tehboii
#1
May 29, 2008, 09:18 pm Last Edit: May 29, 2008, 09:19 pm by tehboii Reason: 1
Quote
It is usually a good idea to uppercase the constants, to avoid confusion with variables. No big deal here, but this may be confusing on bigger projects. So you'd better use :
#define       NUM_OF_ANALOGS      3
Quote
Arduino provides the map() function to do such things. Assigning the result of a division to an integer may (will :) ) lead to a loss of precision.
T.
... could use some sleep
acidhax
You are correct! semester one revision here i go! :P
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
