Loading...
Pages: [1]   Go Down
Author Topic: int question  (Read 314 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Hello,
Still trying to get the hang of programing so here is my noobie question.
Can I define a list of int's followed by a list of int's that are made of various combinations of the first set? A mouthful I know .
here is a simple example for dice, that does not work, of what i am trying to do:
Code:
int A = 3;
int B = 4;
int C = 5;
int D = 6;
int roll1 = A;
int roll2 = B;
int roll3 = A & B;
int roll4 = B & C;
int roll5 = A & B & C;
int roll6 = B & C & D;
  pinMode(A, OUTPUT);
  pinMode(B, OUTPUT);
  pinMode(C, OUTPUT);
  pinMode(D, OUTPUT);
  digitalWrite(roll1, HIGH);
  digitalWrite(roll1, LOW);
  digitalWrite(roll6, HIGH);
  digitalWrite(roll6, LOW);
It verifies just fine but does not do what i want it to.  I tried a couple of different variations however none worked.... obviously. smiley-wink
Thanks
Logged
Paris FR
Offline Offline
Full Member
cute little geek...
View Profile
WWW
You can't do it this way. If you want to write a function changing the status of multiple pins, you can use a bitmask. The & operator is the reference pointer operator.
A bitmask can be, for instance, a byte, of which every bit refers to a different pin, starting from a defined one. If the bit is at 1, it will, ie, sets the pin to HIGH, or to LOW if it is at 0.
Examples :
255d = 11111111b
0d = 00000000b
145d = 10010001
(Here, d stands for decimal, b for binary)
You'll need to understand how you can convert a decimal number to a binary one, or use bitwise operators - They are easy.
Sorry I don't have time to write a code sample, and my answer is very quick. Just look at bitwise function in the extended references and try. But remember you'll HAVE to write a function to do this.
« Last Edit: May 30, 2008, 03:49:05 pm by tehboii » Logged
... could use some sleep
0
Offline Offline
Sr. Member
Got Karma?
View Profile
Are you wanting to do bit AND (&) or just add A and B (+)
Logged
Paris FR
Offline Offline
Full Member
cute little geek...
View Profile
WWW
I understand he is trying to do some kind of bitmask operations to change multiple pins with a single digitalWrite, which is impossible. If this is not what you were trying to do, please just ignore my answer.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I was looking to change the status of multiple pins with a single digitalWrite.  I'll read up on bitmask operations and adjust my code accordingly.
Thanks for the push in the right direction.
Logged
Las Vegas, NV
Offline Offline
God Member
View Profile
WWW
digitalWrite cannot affect multiple pins, but the mega168 allows for this by having its I/O pins on ports.  To set multiple pins at once, you first need to convert the Arduino pin enumeration into port pins (pins 0 - 7 are bits 0 - 7 of port D, pins 8 - 13 are bits 0 - 5 of port B, and analog inputs 0 - 5 are bits 0 - 5 of port C).  You can then do bitmask operations on the port registers, which are each single bytes.  For example, to drive Arduino pins 1, 2, and 5 high, I would do:
DDRD |= (1 << 1) | (1 << 2) | (1 << 5);  // set pins 1, 2, and 5 as digital outputs
PORTD |= (1 << 1) | (1 << 2) | (1 << 5);  // drive pins 1, 2, and 5 HIGH
PORTD &= ~(1 << 1) & ~(1 << 2) & ~(1 << 5);  // drive pins 1, 2, and 5 LOW
- Ben
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Yes the BIT AND operator is a confusion item for you and I understand.  I think raw port programming is not for the faint of heart either.  I just threw together a dice rolling program tonight and I think this little function call will make it easy for you.  I plan on posting some software and hardware layouts at a latter time but for now here is my showDigit function call with variables changed to match your sample code, just do away with digit1 ... digit6 and add code to call showDigit(5) or showDigit(random(1,7)).
void showDigit(int digit) {
    digitalWrite(A, (digit & 1   ? HIGH : LOW));  // turn LED ON/OFF
    digitalWrite(B, (digit >= 2 ? HIGH : LOW));  // turn LED ON/OFF
    digitalWrite(C, (digit >= 4 ? HIGH : LOW));  // turn LED ON/OFF
    digitalWrite(D, (digit == 6 ? HIGH : LOW));  // turn LED ON/OFF
Ron
Freeduino SB
Logged
Las Vegas, NV
Offline Offline
God Member
View Profile
WWW
Quote
In general, I strongly encourage people who are moderately experienced at AVR programming to understand what's going on internally as their code executes.  Hiding away the complexities might make AVR programming more approachable to the beginner, but in the end I think it can become a hinderance to those who want to start accomplishing increasingly complicated tasks or who start focusing on achieving high levels of performance.  It also makes you much more selfreliant should you need to do something that doesn't already have a library devoted to it.
- Ben
Logged
Pages: [1]   Go Up
Print
Jump to:
