Author Topic: function-definition is not allowed..?  (Read 1395 times)
My program gives me this error..
In function 'void loop()':
error: a function-definition is not allowed here before '{' token
the line identifier is at the very last line in my code
what am I doing wrong?  see sample code
//serial handler
//dnear1
//june 12 2008
  char RX[13];
  char nextbyte;
  boolean lostbyte;
  lostbyte=false;
  if(Serial.available() > 0) {
    char temp;
    char numbytes;
  {//my protocol is going to be 20 bb cc (xx xx xx) cs
  //where bb is the number of bytes to be sent,
  //cc is s command
  //xx is any data being sent and
  //cs is the checksum
  do
    if (lostbyte=true)//this may not be the best way to handle it..
      temp=nextbyte;
      lostbyte=false;
      //numbytes=RX[13];
    temp= Serial.read();
  numbytes=RX[13];
  if(numbytes = 0)//is this first byte received in command?
    if(temp = 20)//if so, is it a valid start byte?
      RX[0]=temp;//store it as first byte
      RX[13]=1;//and increment valid byte counter
  if(numbytes = 1)//is this second byte received in command?
    if(temp > 0)//if so, it is number of data bytes in preceding packet
    //it should be greater than zero
      if(temp <=10)//it also should be less than 10.. I can always increase later if I need
      //larger packet to hold something
    RX[1]=temp;//store it in second byte
    RX[13]++;//and increment valid byte counter
      else//if data bytes value is not valid
        RX[13]=0;//then incoming data packet is invalid, clear out and wait
     RX[13]=0;//data bytes value must be greater than zero... it isn't so clear out and wait
  if(numbytes = 2)//is this third byte received in command?
  {//this byte will always be data of some sort IE a command byte
    RX[2]=temp;//store it in third byte
  if(numbytes = 3)//is this fourth byte received in command?
  {//this byte will either be a command, data or checksum
    RX[3]= temp;//store it in fourth byte
  if(numbytes > 3)//is this fifth or consecutive byte in command?
    if (RX[1]>(numbytes-3))//check the length of the packet
    {//if we expect more bytes than we currently have..
      RX[numbytes]=temp;//store it in nth byte;
    {//if we are here then we have more bytes than packet calls for... save it for later and exit loop
      nextbyte=temp;//I need to take care of this byte somehow it may be important to next command
      lostbyte=true;//this is how I think I will handle it..
      break;
  } while (Serial.available() > 0);
  //now we need to check and/or process incoming commands if a complete command is found.
  //process incoming data
« Last Edit: June 12, 2008, 07:11:38 am by dnear1 » Logged
London
Have fun!
The code is difficult to debug because loop is too big to see the wood from the trees. One problem was that  the compiler was getting confused because there were some brackets in the wrong place .
I suggest you move the functionality to check the incoming data into a separate function as per the example below.
The code used a single equals sign to test for equality, in C you use a double equal sign.
if(a=b)  will always return true, it sets a equal to b
if(a== b)  is what you want.
//serial handler
//dnear1
//june 12 2008
char RX[13];
char nextbyte;
boolean lostbyte;
  lostbyte=false;
void checkBytes(int numbytes) {
 int temp;
   // code to check bytes needs to be added here
   // note that this could return a boolean value if you need to break out of your do loop as a result of calculations here
   // remember that a check for equality is: if(a==b)   not: if(a=b);
    char temp;
    char numbytes;
    //my protocol is going to be 20 bb cc (xx xx xx) cs  <- you had a brace here !!
    //cc is s command
    do
      if (lostbyte==true)//this may not be the best way to handle it..  <- this was: lostbyte=true!!
        temp=nextbyte;
        lostbyte=false;
        //numbytes=RX[13];
      numbytes=RX[13];
      checkBytes(numbytes);
  } // <- this was missing !!!
« Last Edit: June 12, 2008, 07:48:10 am by mem » Logged
Grenoble/Lyon - France
I'd say it's this line
but not sure
That line was merely comment.
Thanks for the hint about if statement needs == not =.  hard to retrain myself after years of VB use..
It seems I was missing a } bracket.. after I reorganized and noticed one missing the problem disappeared..
//test run serial handler
  char RX[13];
  char nextbyte;
  boolean lostbyte;
  lostbyte=false;
void checkrx(){
  //cc is s command
    char temp;
    char numbytes;
    do
      temp=nextbyte;
      lostbyte=false;
      //numbytes=RX[13];
  numbytes=RX[13];
  if(numbytes == 0)//is this first byte received in command?
    if(temp == 20)//if so, is it a valid start byte?
  if(numbytes == 1)//is this second byte received in command?
  if(numbytes == 2)//is this third byte received in command?
  if(numbytes == 3)//is this fourth byte received in command?
      break;
  checkrx;
« Last Edit: June 12, 2008, 05:28:47 pm by dnear1 » Logged
yeah, that's a comment, but with a bracket before the comment starter ( // ) and no statement, so the bracket was a pb, i think
