Topic: Random servo movement (Read 1 time) previous topic - next topic
deleteman
Jul 08, 2016, 04:33 pm Last Edit: Jul 09, 2016, 04:39 am by deleteman Reason: adding picture attached
So, let me start by  stating two things:
1- First ever post here.
2- Not sure if this is the right place to ask about this, I'm sorry if it's not.
OK now, onto the problem:
I'm a newcomer to Arduino, and I'm testing a basic setup of a servo motor controlled with a push button. Basically what I want is the servo to move to position 180 when the pushbutton is pressed once, and then move back to 0 when the button is pressed again.
The code for it, is this:
Code: [Select]
#include <Servo.h>
Servo myservo;
int val;
int buttonState = 0;
int lastButtonState= 0 ;
int buttonPin = 2;
int dir = 1;
int ledPin =  13;
int counter = 0;
int lastDebounceTime = 0;
int debounceDelay = 15;
String logMsg = "";
  myservo.attach(9);
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, HIGH);
  myservo.write(0);
  int reading = digitalRead(buttonPin);
  if(reading != lastButtonState) {
    lastDebounceTime = millis();
  if ( (millis() - lastDebounceTime) > debounceDelay) {
    if(reading != buttonState) {
      buttonState = reading;
      if(buttonState == HIGH) {
        dir = 1;
        counter++;
        dir = 0;
      delay(15);
    if(counter % 2              ) {
      while(val < 180) {
       val+= 2;
        myservo.write(val);
        delay(15);
         digitalWrite(ledPin, LOW);
      while(val > 0) {
        val -= 2;
        myservo.write(val);
        delay(15);
  lastButtonState = reading;
My problem is that this works sometimes, and some other times it doesn't, and by doesn't I mean, the servo might stop mid turn and go back, or even go all the way to 180 and then instantly go back to 0 without me pressing the button.
I've been developing for more than 10 years, so I know my code, I'm assuming something in my hardware setup is generating some sort of random signal which triggers this behavior?
The setup is basically the combination of the servo tutorial and the pushbutton tutorials found on this site.
So does anyone have any ideas on what I might be doing wrong that would cause this behavior?
Thanks so much!
MarkT
#1
Jul 08, 2016, 06:42 pm Last Edit: Jul 08, 2016, 06:42 pm by MarkT
Change debounceDelay to 100 perhaps?
Also do you have any pullup or pulldown resistors on that button?
deleteman
Oh  I have tried that, I've played around with different values for the debounce delay, but nothing really worked.
MarkT
I repeat: "Also do you have any pullup or pulldown resistors on that button?"
outsider
#4
Jul 10, 2016, 06:07 pm Last Edit: Jul 10, 2016, 06:08 pm by outsider
Make sure your button is connected like one of these.
bodmer
Put a pulldown in the range 1K to 10K on pin 2 and it will work fine without any code changes.
Don't run the servo off the Arduino 5V pins, use a battery pack of 4 AA cells for the servo because servos typically take quite a high current. The majority of servos are designed to run from 4.8V to 6V.  Make sure you have a common GND (0V) between the Arduino power and the servo battery pack.
coulam123
thanks for tho code will see if it works soon
