Topic: Error while trying to load sketch (Read 18327 times) previous topic - next topic
rahul_2
Arduino: 1.6.10 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 1,634 bytes (0%) of program storage space. Maximum is 253,952 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 8,177 bytes for local variables. Maximum is 8,192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM6 -b115200 -D -Uflash:w:C:\Users\RAJESH~1\AppData\Local\Temp\builddb8ae029c159ec667d6c55be7f7f7907.tmp/sketch_dec16a.ino.hex:i
An error occurred while uploading the sketch
option enabled in File -> Preferences.
pert
Please update to Arduino IDE 1.6.13.
Woodward
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
Build options changed, rebuilding all
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
pert
Select the COM port of your Arduino from the Tools > Port menu.
sterretje
#19
Feb 11, 2017, 06:18 pm Last Edit: Feb 11, 2017, 06:19 pm by sterretje
I don't see a question.
Maybe give a little more info if you need help. Did it work before? Installed any new software before this started happening? Is the board still recognized in the device manger? Is it indeed com3?
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
roy_calonge
buenas tardes, tengo arduino uno y al tratar de cargar un sketch recibo cierto tipo de error, he mirado muchos post pero ninguno dice nada referente a como solucionarlo, espero me puedan ayudar.
este es el mensaje de error que me da al tratar decargarlo a mi tarjeta:
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\CDC.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\HardwareSerial.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\HardwareSerial0.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\HardwareSerial1.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\HardwareSerial2.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\HardwareSerial3.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\IPAddress.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\PluggableUSB.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\Print.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\Stream.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\Tone.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\USBCore.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\WMath.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\WString.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\abi.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\main.cpp.o"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\core.a" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\core\new.cpp.o"
Archiving built core (caching) in: C:\Users\lyon\AppData\Local\Temp\arduino_cache_355129\core\core_arduino_avr_uno_5638c217b04eda8279099c4937887265.a
Linking everything together...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.elf" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582\sketch\Blink.ino.cpp.o" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/core\core.a" "-LC:\Users\lyon\AppData\Local\Temp\arduino_build_395582" -lm
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.elf" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.eep"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.elf" "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.hex"
El Sketch usa 928 bytes (2%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 9 bytes (0%) de la memoria dinámica, dejando 2039 bytes para las variables locales. El máximo es 2048 bytes.
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
        Copyright (c) 2007-2014 Joerg Wunsch
        System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
        Using Port                    : COM4
        Using Programmer              : arduino
        Overriding Baud Rate          : 115200
        AVR Part                      : ATmega328P
        Chip Erase delay              : 9000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : Arduino
        Description     : Arduino
        Hardware Version: 3
        Firmware Version: 4.4
        Vtarget         : 0.3 V
        Varef           : 0.3 V
        Oscillator      : 28.800 kHz
        SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% -0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.hex"
avrdude: writing flash (928 bytes):
Writing | ################################################## | 100% 0.16s
avrdude: 928 bytes of flash written
avrdude: verifying flash memory against C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.hex:
avrdude: input file C:\Users\lyon\AppData\Local\Temp\arduino_build_395582/Blink.ino.hex contains 928 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.12s
avrdude: verifying ...
avrdude: 928 bytes of flash verified
avrdude done.  Thank you.
colarunkumar
Arduino: 1.8.7 (Windows Store 1.8.15.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1094 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 13 bytes (0%) of dynamic memory, leaving 2035 bytes for local variables. Maximum is 2048 bytes.
Invalid library found in C:\Users\Arun kumar chaubey\Documents\Arduino\libraries\FJVZ326IJKEMNVI: no headers files (.h) found in C:\Users\Arun kumar chaubey\Documents\Arduino\libraries\FJVZ326IJKEMNVI
what to do how to solve error
