Topic: Error (Read 1 time) previous topic - next topic
KuldaCz
Hello , i have a problem with my code , and the problem is big error. I have an arduino uno.
Code: [Select]
Arduino: 1.6.7 (Windows 10), Vývojová deska: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
WARNING: Category '' in library ArduinoUnit is not valid. Setting to 'Uncategorized'
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp: In function 'bool recvRetNumber(uint32_t*, uint32_t)':
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:67:31: warning: left shift count >= width of type [enabled by default]
         *number = (temp[4] << 24) | (temp[3] << 16) | (temp[2] << 8) | (temp[1]);
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:67:49: warning: left shift count >= width of type [enabled by default]
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:75:40: error: 'dbSerialPrint' was not declared in this scope
         dbSerialPrint("recvRetNumber :");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:76:32: error: 'dbSerialPrintln' was not declared in this scope
         dbSerialPrintln(*number);
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:80:44: error: 'dbSerialPrintln' was not declared in this scope
         dbSerialPrintln("recvRetNumber err");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp: In function 'uint16_t recvRetString(char*, uint16_t, uint32_t)':
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:150:35: error: 'dbSerialPrint' was not declared in this scope
     dbSerialPrint("recvRetString[");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:154:24: error: 'dbSerialPrintln' was not declared in this scope
     dbSerialPrintln("]");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp: In function 'bool recvRetCommandFinished(uint32_t)':
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:209:52: error: 'dbSerialPrintln' was not declared in this scope
         dbSerialPrintln("recvRetCommandFinished ok");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:213:53: error: 'dbSerialPrintln' was not declared in this scope
         dbSerialPrintln("recvRetCommandFinished err");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp: In function 'bool nexInit()':
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:225:23: error: 'dbSerialBegin' was not declared in this scope
     dbSerialBegin(9600);
exit status 1
Chyba kompilace.
  Tento výpis by měl více informací s
  "Zobrazit více informací během kompilace"
  povoleno v Soubor > Vlastnosti
Could you help me solve this issue? :D
KuldaCz
oh sorry i change an error
Code: [Select]
#include "Nextion.h"
#include "Arduino.h"
void okPopCallback(void *ptr);
void zamkPopCallback(void *ptr);
NexText heslo = NexText(1, 1, "t0");
NexText vp = NexText(1, 17, "t1");
NexButton ok = NexButton(1, 12, "enter");
NexButton zamk = NexButton(3, 5, "b1");
char buffer[100] = {0};
NexTouch *nex_listen_list[] =
    &ok,
    NULL
//kontrola správnosti hesla
    memset(buffer, 0, sizeof(buffer));
    heslo.getText(buffer ,sizeof(buffer));
    if (strcmp(buffer,"1235"))
      digitalWrite(4, HIGH);
      strcpy(buffer, "OK");
    }else{
      digitalWrite(4, LOW);
      strcpy(buffer, "NE");
     vp.setText(buffer);
void setup(void) {
  pinMode(4, OUTPUT);
  nexInit();
  ok.attachPop(okPopCallback);
  zamk.attachPop(zamkPopCallback);
void loop(void) {
 nexLoop(nex_listen_list);
KuldaCz
And this i have in NexConfig.h
Code: [Select]
 * @file NexConfig.h
 * Options for user can be found here.
 * @author  Wu Pengfei (email:<pengfei.wu@itead.cc>)
 * @date    2015/8/13
 * @copyright
 * Copyright (C) 2014-2015 ITEAD Intelligent Systems Co., Ltd. \n
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License as
 * published by the Free Software Foundation; either version 2 of
 * the License, or (at your option) any later version.
#ifndef __NEXCONFIG_H__
#define __NEXCONFIG_H__
 * @addtogroup Configuration
 * Define DEBUG_SERIAL_ENABLE to enable debug serial.
 * Comment it to disable debug serial.
#define DEBUG_SERIAL_ENABLE
 * Define dbSerial for the output of debug messages.
#define dbSerial Serial
 * Define nexSerial for communicate with Nextion touch panel.
#define nexSerial Serial3
#ifdef DEBUG_SERIAL_ENABLE
#define dbSerial2Print(a)    dbSerial2.print(a)
#define dbSerial2Println(a)  dbSerial2.println(a)
#define dbSerial2Begin(a)    dbSerial2.begin(a)
#else
#define dbSerial2Print(a)    do{}while(0)
#define dbSerial2Println(a)  do{}while(0)
#define dbSerial2Begin(a)    do{}while(0)
#endif
#endif /* #ifndef __NEXCONFIG_H__ */
AWOL
Code: [Select]
Sixteen bit int arithmetic doesn't allow a left shift of 24 bits.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
KuldaCz
#4
Aug 02, 2016, 12:04 pm Last Edit: Aug 02, 2016, 12:10 pm by KuldaCz
Ok, but this is from nextion library , so how can i fix it ?
AWOL
You have the source of the library - add some "(uint32_t)" casts.
KuldaCz
yeah and what? i still dont underestand what do you mean ?
AWOL
Code: [Select]
should be
Code: [Select]
*number = ((uint32_t)temp[4] << 24) | ((uint32_t)temp[3] << 16) | ((uint32_t)temp[2] << 8) | (temp[1]);
KuldaCz
now it have this problem
Code: [Select]
exit status 1
AWOL
The compiler has told you exactly what the problem is.
KuldaCz
But the problem is that , that i have declared debug serial disabled.
operrr
I solved this problem SEE ON YOUTUBE
