Topic: Problems with 4794's in series!! (Read 742 times) previous topic - next topic
markisgod
I'm using an arduino to power two 4794 LED drivers, so I can display digits on my two 7 segment LEDs. Unfortunately, it isn't working properly.
I can display any number, 00-99, but everytime a 1, 4, or 9 shows up on the display on the right a segment is lit up that shouldn't be.
I've checked everything and it seems to be fine. What's wrong!!?
Here's the datasheet for the 4794s:
http://www.nxp.com/acrobat_download/datasheets/HEF4794B_3.pdf
And here's my code:
Code: [Select]
int data = 9;
int strob = 8;
int clock = 10;
int oe = 11;
int count = 0;
long dato = 0;
int velocity = 00;
long binaryLED = 0;
 pinMode(data, OUTPUT);
 pinMode(clock, OUTPUT);
 pinMode(strob, OUTPUT);
 pinMode(oe, OUTPUT);
 convert(velocity);
 segmentWrite();
 velocity++;
 if(velocity==100){velocity=0;}
void segmentWrite(){
  dato = binaryLED;
  for (count = 0; count < 16; count++) {
   digitalWrite(data, dato & 01);
   dato>>=1;
   if (count == 15){
   digitalWrite(oe, LOW);
   digitalWrite(strob, HIGH);
   PulseClock();
    digitalWrite(oe, HIGH);
 delayMicroseconds(20);
 digitalWrite(strob, LOW);
 delay(100);
 serialWrite(10);
 serialWrite(13);
delay(100);                  // waits for a moment
void PulseClock(void) {
   digitalWrite(clock, LOW);
   digitalWrite(clock, HIGH);
   delayMicroseconds(50);
int convert(int number){
    int i = 0;
    int numberl = 0;
    int numberr = 0;
    while(10*i<=number){
      i++;
    numberl = i - 1;
    numberr = number - (10 * numberl);
    binaryLED = 0;
    if(numberl==0){
      binaryLED = 32256;
    }else if(numberl==1){
      binaryLED = 4608;
    }else if(numberl==2){
      binaryLED = 48128;
    }else if(numberl==3){
      binaryLED = 46592;
    }else if(numberl==4){
      binaryLED = 53760;
    }else if(numberl==5){
      binaryLED = 58880;
    }else if(numberl==6){
      binaryLED = 60928;
    }else if(numberl==7){
      binaryLED = 12800;
    }else if(numberl==8){
      binaryLED = 65024;
    }else if(numberl==9){
      binaryLED = 61952;
    if(numberr==0){
      binaryLED = binaryLED + 126;
    }else if(numberr==1){
      binaryLED = binaryLED + 18;
    }else if(numberr==2){
      binaryLED = binaryLED + 188;
    }else if(numberr==3){
      binaryLED = binaryLED + 182;
    }else if(numberr==4){
      binaryLED = binaryLED + 210;
    }else if(numberr==5){
      binaryLED = binaryLED + 230;
    }else if(numberr==6){
      binaryLED = binaryLED + 238;
    }else if(numberr==7){
      binaryLED = binaryLED + 50;
    }else if(numberr==8){
      binaryLED = binaryLED + 254;
    }else if(numberr==9){
      binaryLED = binaryLED + 242;
