Topic: need help in codes! (Read 3841 times) previous topic - next topic
gr33nhorn
[code][#include <math.h>
#define Header 0xff
byte *PosPtr;
byte ZeroPosArray[]={/* ID 0 ,  1 ,  2 ,  3 ,  4 ,  5 ,  6 ,  7 ,  8 ,   9,  10 ,  11 */
                         10 , 20 , 30 , 40 , 50 , 60 , 70 , 80 , 90 , 100, 111 , 120
                   };        //initial positions.
byte WalkPosArray[5][12]={/* ID 0 ,  1 ,  2 ,  3 ,  4 ,  5 ,  6 ,  7 ,  8 ,   9,  10 ,  11 */
                             {10 , 20 , 30 , 40 , 50 , 60 , 70 , 80 , 90 , 100, 110 , 120}, //Index:0 -ViaPoint_0
                             {20 , 30 , 40 , 50 , 60 , 70 , 80 , 90 ,100 , 110, 120 , 130}, //Index:1 -ViaPoint_1
                             {30 , 40 , 50 , 60 , 70 , 80 , 90 ,100 ,110 , 120, 130 , 140}, //Index:0 -ViaPoint_2
                             {40 , 50 , 60 , 70 , 80 , 90 ,100 ,110 ,120 , 130, 140 , 150}, //Index:0 -ViaPoint_3
                             {50 , 60 , 70 , 80 , 90 ,100 ,110 ,120 ,130 , 140, 150 , 160}  //Index:4 -ViaPoint_0
   byte LastID, Torque;
   LastID=11;
   Torque=4; //0~4
   PosPtr=ZeroPosArray;
   SyncPosSend(LastID,Torque,PosPtr);//initialise
void SyncPosSend(byte LastID, byte Torque ,byte *PosPtr)
 byte i, Checksum;
 i=0;
 Checksum=0;
 Serial.print(Header,BYTE);
 Serial.print((Torque<<5)|0x1f,BYTE);
 Serial.print(LastID+1,BYTE);
   for(i=0; i<=LastID; i++)
       Serial.print(*(PosPtr+i),DEC);
       Checksum ^=*(PosPtr+i);
 Checksum &=0x7f;
 Serial.print(Checksum,BYTE);
/code]
i  have added a 2dArray and is intended to access it after acessed zeroposarray[], so how am i going to access the multi array if i'm going to use the SyncPosSend() function to access it too?please enlighten me.
gr33nhorn
My question on C....say...i have a 2d array of [3][4].......how can i use the values in this array and dump into a function whereby it will calculate the average value in
  • [1] and
  • [2] and put back into a new 2d array?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
