Topic: I can't upload Nextion library (Read 637 times) previous topic - next topic
a28s5162
Aug 06, 2016, 10:06 am Last Edit: Aug 06, 2016, 10:38 am by a28s5162
I can upload my sketch to web creator beacuse I'm using Nextion library and it's not possible to upload it to custom librarys. The problem is the size of library and the web creator has a limit the size to upload to 1 Mb and the library is bigger than 1 Mb.
So, how can I upload this library?
Thanks in advance,
ballscrewbob
#1
Aug 06, 2016, 02:03 pm Last Edit: Aug 06, 2016, 02:12 pm by Ballscrewbob
Yes its over 12 mb.
The web IDE is a "work in progress" so you might want to open an issue on the GitHub site for it.
BTW this is not the FULL github repo as that is still private apparently.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
matteosuppo
Hi, are you sure that you can't slim the library down? If there are pdf files inside it you can safely remove them, they exists only for documentation.
http://www.google.it
ballscrewbob
Matt is correct.
If you remove the examples and the docs it goes under 70k.
You can always load the examples as your sketches.
Thanks Matt
