Topic: problem returning array from function... (Read 994 times) previous topic - next topic
wrybread
I'm trying to use a function to generate an array. Below is a stripped down version of my code. In the loop, the variable named "pattern" should get an array of numbers from the function generatePattern(). Thanks for any help.
int pattern_local[] = {1, 2};
int pattern[] = {3, 4};
 pattern = generatePattern();
int generatePattern()
return pattern_local;
This errors out with:
In function 'void loop()':
error: incompatible types in assignment of 'int' to 'int [2]' In function 'int generatePattern()':
Can anyone point me in the right direction?
BetaDelta
The array contains two integers and you cannot assign them to a single integer. so you need to choose one value in the array to assign or do some maths!
/me
"C++ : Where friends have access to your private members." - Gavin Russell Baker
halley
#2
Apr 15, 2009, 04:01 pm Last Edit: Apr 15, 2009, 04:01 pm by halley Reason: 1
Don't write functions to "return an array."
Write functions that can fill out a given array.  Remember to tell the function how long the array is.
#define PATTERN_LENGTH 2
int the_pattern[PATTERN_LENGTH];
   generatePattern(the_pattern, PATTERN_LENGTH);
void generatePattern(int pattern[], int length)
   int value = 1;
   for (int i = 0; i < length; i++)
       pattern[i] = value;
       value++;
