Topic: connect 4 sensors and a GPS , best way ?? (Read 178 times) previous topic - next topic
jtabatch
Hi
I need to connect 3 thermocouples , a  GPS and a Pyranometer .  Any suggestions .  Was thinking of starting out with the Intel Edison kit for Arduino and expanding from there . Would I connect these sensors to serial ports and if so is there an Arduino with multiple serial ports.
Thanks
Justin Tabatchnick
MorganS
Thermocouples can't be connected directly to the Arduino. You need a converter chip such as a MAX31855. They're really tricky to work with. If you don't need the temperature range of the thermocouple, there's much better temperature sensors. I like the BMP280 which has an astoundingly good humidity sensor. As a a plain temperature-only sensor with an analog output, the LM335Z is pretty good.
The Teensy 3.x has 3 serial ports. The Due and the Mega have 4.
The Edison is probably not the best choice as your first Arduino.
"The problem is in the code you didn't post."
