Topic: Problems with floating point division (Read 888 times) previous topic - next topic
Justin56
I'm having problems dividing a floating point number and getting a floating point answer.  It boils down to normally being around 50.3959/60 to convert minutes to degrees, but when I attempt to do that the number returned is a 0.
float convertLat(char lat[9])
 float latFloat;
 latFloat = (lat[0]-0x30)*10 + (lat[1]-0x30) + ((lat[2]-0x30)*10 + (lat[3]-0x30) + (lat[5]-0x30)/10 + (lat[6]-0x30)/100 + (lat[7]-0x30)/1000 + (lat[8]-0x30)/10000)/60;
 return latFloat;
crimony
The problem here is that the float conversion only happens after all the arithmetic evaluation takes place, ie. all the divisions in your code are integer.
You need to cast the chars to floats before you divide and use float literals (like 10.0) rather than integer literals (like 10):
latFloat = (lat[0]-0x30)*10 + (lat[1]-0x30) + ((lat[2]-0x30)*10 + (lat[3]-0x30) + (float)(lat[5]-0x30)/10.0 + (float)(lat[6]-0x30)/100.0 + (float)(lat[7]-0x30)/1000.0 + (float)(lat[8]-0x30)/10000.0)/60.0;
RIDDICK
i would recommend to use integers as long as possible and then use float/double-multiplication instead of float-division in order to save processing time (IIRC)...
example (i assume: 0x30 <= lat < 0x3a -- ascii: '0'..'9'):
(lat[0]-0x30)*10 +
(lat[1]-0x30) +
(lat[2])-0x30)*10 +
(lat[3])-0x30) +
(lat[5])-0x30)*1e-1 +
(lat[6])-0x30)*1e-2 +
(lat[7])-0x30)*1e-3 +
(lat[8])-0x30)*1e-4
)*(1/(float)60);
if u want shorter code u can use this (maybe the compiler unrolls the loop):
float result = (lat[0]-0x30)*10 + (lat[1]-0x30);
float fac=10/(float)60;
for (register uint8_t j=2; j<=8; j++, fac*=1e-1)
 result += (lat[j]-0x30) * fac;
-arne
