Topic: Assiging contents of one array to another? (Read 828 times) previous topic - next topic
SoundGuyAndy
Perhaps a stupid question....can I assign the contents of one array to another in one single line, or do I need to do it position by position in a loop?
I've got a program with a dozen or so arrays, and at various points I need to serial.print the contents of those arrays, and I'm trying to simplify this to a single function, rather than have to repeat the code a dozen times.
So, can I declare the function like this:
void sendMsg(byte msgString[])
and then call it like this:
sendMsg(array_name_here)?
Will that plug the entire contents of the array in as the contents of msgString, or not? If not, is there another way to do this easily/efficiently?
Thanks,
Andy
interlol
#1
Apr 30, 2009, 09:39 am Last Edit: Apr 30, 2009, 09:46 am by interlol Reason: 1
Try this on your computer, not in the Arduino but it's the same language:
#include <cstdio>
typedef unsigned char byte;
   // print the address of the things, is it a copy? no, it's just a pointer!
   printf("Address of the array in sendMsg: %x\n", msgString);
int main()
   byte things[20];
   // first test: print the address of things
   printf("Address of the array in main: %x\n", things);
   // second test
   sendMsg(things);
The program will print the same address!
Address of the array in main: bffff70c
Address of the array in sendMsg: bffff70c
In reality, when you declare void sendMsg(byte msgString[]), msgString is a pointer to the array sent as a parameter of the function, nothing is copied, but all the values are accessible in your function because it's the original array address that is being given.
Be very careful though: the C and the C++ do not keep the "length" of the array (given as a parameter, or inside the main function), you have to know it, otherwise you'll get a buffer overflow somewhere.
To conclude:
  • there is no copy (or it has to be explicite with functions like memcpy)
  • you have to be careful not to access values outside the array (keep the length, and the largest index is (length-1))
  • this was not a stupid question, it's actually a problem for a lot of programmers ;)
SoundGuyAndy
Great, I was hoping it'd be that simple, but didn't know enough to be sure! Thanks :-)
