Topic: SOLVED: Send EMAIL using SIM-5320 (3G) HELP please! (Read 4131 times) previous topic - next topic
lastchancename
Aug 17, 2016, 06:32 am Last Edit: Aug 30, 2016, 07:46 am by lastchancename
SOLVED - SEE LAST REPLY
Trying to use current model SIMCOM 5320 modem to end email...
Sooo close, but no prize - yet.s
Unfortunately, it's a bit different to the SIM900, as it implements a newer version of the AT command set.
Is there anyone here that can help, or has experience in what I'm missing?
Should I revert to the 'old' AT email commands - or will they become extinct within my lifetime!?
POWER ON - FIRST attempt
Quote
AT+CGATT=1 OK
AT+CGDCONT=1, "IP", "internet", "0.0.0.0"
AT+CGACT=1, 1 OK
AT+CGPADDR=1 >> +CGPADDR: 1,"10.146.53.134"  <<==  ASSIGNED IP ADDRESS
AT+CSMTPSSRV="smtp.optusnet.com.au", 465, 2
AT+CSMTPSAUTH=0
AT+CSMTPSFROM="a_user@gmail.com"
AT+CSMTPSRCPT=0,0,"b_user@gmail.com", "Controller Report"
AT+CSMTPSSUB=17
   Controller Report
AT+CSMTPSBODY=62
   internode test
   Test message body
   on multiple lines
   We 22:50
OK
+CSMTPSSEND: 8  <<== NETWORK ERROR
Immediately after - make SECOND attempt
Quote
AT+CGATT=1 OK
AT+CGACT=1, 1 OK
AT+CGPADDR=1 >> +CGPADDR: 1,"0.0.0.0"  <<==  IP ADDRESS HAS GONE ??!
AT+CSMTPSAUTH=0
AT+CSMTPSSUB=17
   ControlMate Report
AT+CSMTPSBODY=62
   internode test
   Test message body
   on multiple lines
   We 22:53
+CSMTPSSEND: 255  <<== UNKNOWN ERROR
Note the IP address has gone on the second attempt!
I didn't drop the connection
I tried with optus and gmail servers - same result
Finally power cycle - then a THIRD attempt - result identical to the FIRST
Which makes me think the modem is receiving all the commands - and getting into 'a mode' where it won't accept another 'send' until the previous one is sent, or the modem is power cycled (clearing the operational states)
http://www.edaboard.com/thread125473.html seems to suggest we're doing the right stuff...
The lost IP address may occur because I'm establishing the connection 'again' - but I don't think so.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
acitta
I have a 3G module in the post so I can't help yet but maybe once it arrives we can collaborate. I did however buy the sim5216 because there appears to be a lot more AT command manuals related to HTTP access. I'm not sure what the difference the two modules is though. The sim800-900 had very similar AT commands, so with any luck the 5216 and 5320 will be similar too. Have you tried using the SIM5216 at command manual?
I also can't remember exactly why, but there was a reason I couldn't use SIM900 modules with my gmail account. I think it was to do with port access on googles end not allowing the type of connection the GSM module makes. Not sure if the SIM5320 has a way around that
lastchancename
Thanks for the thoughts.
I'lll take a look at the 5216 ref. manuals...  as noted above, the 5320 implements BOTH the older SMTP commands, as well as the newer CSMTPSxx commands - which I decided to go with for future-proof compatibility - but if it gets too hard, I'll fall back to the older commands for now.
There are a number of error possibilities - and only these two show up...
    8=NETWORK ERROR
    255=UNKNOWN ERROR
...Are the least helpful... !
There are specific error responses for server, recipient, authentication etc - but they all seem to be for 'later' (!)
lastchancename
SOLVED
The sequence that worked - as below
Quote
AT+CGDCONT=1, "IP", "myAPN", "0.0.0.0" >>
AT+CGATT=1 OK
  <takes ~5 secs>
AT+CGACT=1, 1 >>
+CGPADDR: 1,"10.146.90.214"       << == assigned DHCP from carrier
AT+CSMTPSSRV="smtp.optusnet.com.au", 25, 1
AT+CSMTPSAUTH=0
AT+CSMTPSFROM="sendername@optusnet.com.au"
AT+CSMTPSRCPT=0,0,"recipient@destination.net", "Test Report"
AT+CSMTPSSUB=38
  ControlMate [Test Board] Status Report
AT+CSMTPSBODY=66
  Version 160830
  NEW Test message
  body
  on multiple
  lines
Tu 15:44
>> SENDING...
  <takes ~5 secs>
+CSMTPSSEND: 0
AT+CGACT=0, 1 OK
AT+CGATT=0 OK
AT+CGDCONT=1 OK
Not sure what I changed - perhaps it's just the weather.
AndyM
I know this thread is over 12 months old,but I have only recently purchased the Tinysine 3G shield.(uses SIM 5320)
Is there any update on your work?
Thanks
lastchancename
I hadn't been playing with the GPRS (data) side of things - but this code certainly worked last time I touched it.
I suspect it could be tweaked a bit for efficiency - but it was robust - which counts!
My current call in-out /SMS tools are asynchronous - and I really should upgrade this as well - so the main loop() never blocks while the modem is working in the background
MaxJuke
Hello.
I would like to continue and develop the topic of sending a letter to an email via 3G shield. Interested in this topic. I stumbled upon a project where the author transmits with the help of sim5320 to an email not just text, but first takes a photo with the camera VC0706, and then sends it with the attached photo. In short: this is an email camera. I think someone else might be interested too.
Link: https://www.instructables.com/id/Email-Camera-VC0706-3G-Shield-Arduino-M0-Analogue/
