Topic: Convert c code to pde sketch file (Read 5615 times) previous topic - next topic
BobW
Am new to Arduino.
Using Atmega 328.
Have mastered basic tasks.
Question:
I want to try some c code I downloaded (google: AVR314 - DTMF generator).
How can I convert the c code I downloaded to a pde sketch file usable by the arduino software?
Thank you.
BobW
GrooveFlotilla
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
BobW
Cut and paste did not work.
Structure of file is not the same.
Fo example, rquired void loop() is not present.
Also problems finding "includes".
BobW
GrooveFlotilla
BobW
//* A P P L I C A T I O N   N O T E   F O R   T H E   A V R   F A M I L Y
//* Number               : AVR314
//* File Name            : "dtmf.c"
//* Title                : DTMF Generator
//* Date                 : 00.06.27
//* Version              : 1.0
//* Target MCU           : Any AVR with SRAM, 8 I/O pins and PWM
//* DESCRIPTION
//* This Application note describes how to generate DTMF tones using a single
//* 8 bit PWM output.
#include <stdio.h>
#define __IAR_SYSTEMS_ASM__
#include <io4414.h>
#include "ina90.h"
#define  Xtal       8000000          // system clock frequency
#define  prescaler  1                // timer1 prescaler
#define  N_samples  128              // Number of samples in lookup table
#define  Fck        Xtal/prescaler   // Timer1 working frequency
#define  delaycyc   10               // port B setup delay cycles
//************************** SIN TABLE *************************************
// Samples table : one period sampled on 128 samples and
// quantized on 7 bit
flash unsigned char auc_SinParam [128] = {
64,67,
70,73,
76,79,
82,85,
88,91,
94,96,
99,102,
104,106,
109,111,
113,115,
117,118,
120,121,
123,124,
125,126,
126,127,
127,127,
127,127,
127,127,
126,126,
125,124,
123,121,
120,118,
117,115,
113,111,
109,106,
104,102,
99,96,
94,91,
88,85,
82,79,
76,73,
70,67,
64,60,
57,54,
51,48,
45,42,
39,36,
33,31,
28,25,
23,21,
18,16,
14,12,
10,9,
7,6,
4,3,
2,1,
1,0,
0,0,
0,0,
0,0,
1,1,
2,3,
4,6,
7,9,
10,12,
14,16,
18,21,
23,25,
28,31,
33,36,
39,42,
45,48,
51,54,
57,60};
//***************************  x_SW  ***************************************
//Table of x_SW (excess 8): x_SW = ROUND(8*N_samples*f*510/Fck)
//high frequency (coloun)
//1209hz  ---> x_SW = 79
//1336hz  ---> x_SW = 87
//1477hz  ---> x_SW = 96
//1633hz  ---> x_SW = 107
const unsigned char auc_frequencyH [4] = {
107,96,
87,79};
//low frequency (row)
//697hz  ---> x_SW = 46
//770hz  ---> x_SW = 50
//852hz  ---> x_SW = 56
//941hz  ---> x_SW = 61
const unsigned char auc_frequencyL [4] = {
61,56,
50,46};
//**************************  global variables  ****************************
unsigned char x_SWa = 0x00;               // step width of high frequency
unsigned char x_SWb = 0x00;               // step width of low frequency
unsigned int  i_CurSinValA = 0;           // position freq. A in LUT (extended format)
unsigned int  i_CurSinValB = 0;           // position freq. B in LUT (extended format)
unsigned int  i_TmpSinValA;               // position freq. A in LUT (actual position)
unsigned int  i_TmpSinValB;               // position freq. B in LUT (actual position)
// Timer overflow interrupt service routine
void interrupt [TIMER1_OVF1_vect] ISR_T1_Overflow (void)
 // move Pointer about step width aheaed
 i_CurSinValA += x_SWa;
 i_CurSinValB += x_SWb;
 // normalize Temp-Pointer
 i_TmpSinValA  =  (char)(((i_CurSinValA+4) >> 3)&(0x007F));
 i_TmpSinValB  =  (char)(((i_CurSinValB+4) >> 3)&(0x007F));
 // calculate PWM value: high frequency value + 3/4 low frequency value
 OCR1A = (auc_SinParam[i_TmpSinValA] + (auc_SinParam[i_TmpSinValB]-(auc_SinParam[i_TmpSinValB]>>2)));
// Initialization
void init (void)
 TIMSK  = 0x80;                     // Int T1 Overflow enabled
 TCCR1A = (1<<COM1A1)+(1<<PWM10);   // non inverting / 8Bit PWM
 TCCR1B = (1<<CS10);                // CLK/1
 DDRD   = (1 << PD5);               // PD5 (OC1A) as output
 _SEI();                                // Interrupts enabled
// Time delay to ensure a correct setting of the pins of Port B
void Delay (void)
 int i;
 for (i = 0; i < delaycyc; i++) _NOP();
// MAIN
// Read from portB (eg: using evaluation board switch) which
// tone to generate, extract mixing high frequency
// (column) and low frequency (row), and then
// fix x_SWa and x_SWb
// row    -> PINB high nibble
// column -> PINB low nibble
void main (void)
 unsigned char uc_Input;
 unsigned char uc_Counter = 0;
 init();
 for(;;){
   // high nibble - rows
   DDRB  = 0x0F;                     // high nibble input / low nibble output
   PORTB = 0xF0;                     // high nibble pull up / low nibble low value
   uc_Counter = 0;
   Delay();                          // wait for Port B lines to be set up correctly
   uc_Input = PINB;                  // read Port B
   do
     if(!(uc_Input & 0x80))          // check if MSB is low
                                     // if yes get step width and end loop
       x_SWb = auc_frequencyL[uc_Counter];
       uc_Counter = 4;
       x_SWb = 0;                    // no frequency modulation needed
     uc_Counter++;
     uc_Input = uc_Input << 1;       // shift Bits one left
   } while ((uc_Counter < 4));
   // low nibble - columns
   DDRB  = 0xF0;                     // high nibble output / low nibble input
   PORTB = 0x0F;                     // high nibble low value / low nibble pull up
   uc_Counter = 0;
   uc_Input = PINB;
   uc_Input = uc_Input << 4;
   do
                                     // if yes get delay and end loop
       x_SWa = auc_frequencyH[uc_Counter];
       uc_Counter = 4;
       x_SWa = 0;
     uc_Counter++;
   } while (uc_Counter < 4);
GrooveFlotilla
The loop with the smiley "for ( ; ; )"  is the bulk of your "void loop()".
You need to strip out the "main"
"setup" looks straightforward, it's the bit before the endless loop.
Can you try to use the "code" button above when posting sketches?
It makes it easier to read and scroll through.
pwillard
#6
Jul 02, 2009, 06:44 pm Last Edit: Jul 02, 2009, 06:46 pm by pwillard Reason: 1
Sure... C is basically C... but then there is the SPECIFIC stuff that Arduino hides from you... that this code doesn't.  You kind of have to figure out how to make the source code you have make a compromise with what the Arduino environment wants.
Code written for the AVRGCC environment might "almost" be a simple as cut and paste, however, code written for IAR's version of C may not be so easy.  If I recall correctly, IAR  might do some heavy lifting that isn't obvious.
IE;
#define __IAR_SYSTEMS_ASM__   <-- This can hurt!  what does it do?
These two you have... but are they compatible?
#include <io4414.h>
#include "ina90.h"
The stuff below definitely needs fixing:
if you don't get the clock stuff worked out... you will not get the frequencies you want.
You kind of gave yourself a big conversion task ahead so you will need to know what you are trying to do.
zooto68
Please do not post great big long reams of code. There is a CODE button right above where you type your text when making a post. Click that, then past your code inbetween the inserted tags. That way we don't have to scroll down pages and pages to read your post. Thanks.
BobW
I'm sorry.
I did not know about the code button.
I see it now.
I will use it next time.
BobW
