Topic: A6 gprs/gsm (Read 48683 times) previous topic - next topic
john1944
Problems getting the A6 to work. I'm using Elecrow shield on a Uno.
Before destroying something are the following points correct:
1. With the Uno,  SoftwareSerial is required at 11500 baud.
2. power_key must be connected to +5V for a couple of seconds.  The Elecrow board as a push button to do this.  It is also tied to D7 which does nothing.  Am I correct that the full 5V are needed so an Arduino output is not adequate.  Is it also OK to permanently hardwire this connection so there is no need to press a button?
3. The Uno has an insufficient power supply for the A6.  A separate 2A source is needed.
Thanks
dannable
Take a look at the page in my signature. Whilst it's not A6 specific it does answer a lot of your questions.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
Lou
Hello,
I had a bad experience with au Uno+A6 modem in its board version (not new A6 Arduino Shield as you own), regarding SoftwareSerial issues (impossible to get any reply back from AT commands sent...):
did you meet these problems (or any other) with your Uno+A6 shield ?
Please let us know :)
Have a good day.
Lou.
Lou
lavos3rd
Here's a website where someone managed to work the A6+Uno Combo.
JAG Electronics
davidgamonpadilla
Why can not I connect to the A6 module through the serial port pin 0 and 1?
unnikartha
I am trying to use A6 module to post data to IBM watson IoT. Which is the best place to get an example?
Reska
#21
Apr 25, 2018, 05:54 pm Last Edit: Apr 26, 2018, 09:22 am by Reska
Hello everyone,
I have problem with my GSM A6 Module, the program runs well but when I unplug and plug the power supply of the module and arduino board, it does not work again ! until I upload a sketch which use serial monitor to communicate with the module by AT command, and then I upload again my program to work again ! it is problem of synchronization between arduino and the module at the beginning when powered up ? what would make the module works olnly one tme until it is powered off ? please can you help me guys !
thankx !
this is the program based on a youtube channel :
#include <SoftwareSerial.h>
 SoftwareSerial mySerial(10, 11);  // RX-Pin10, TX-Pin11
 unsigned char Buff[250];
 unsigned char BuffIndex;
 boolean Act = false;
   //Serial.begin(4800);
mySerial.begin(9600);
pinMode(9, OUTPUT);
digitalWrite(9,HIGH);
   //Serial.println("GSM Tutorial, Valetron Systems @www.raviyp.com ");
   delay(3000);
   mySerial.println("AT+CMGF=1");
   delay(3000);
   mySerial.println("AT+CNMI=2,2,0,0,0");
   memset(Buff, '\0', 250);    // Initialize the string
   BuffIndex=5;
void SMS_Marche() {
 //mySerial.write(0x0D);  // hex equivalent of Carraige return
 //mySerial.write(0x0A);  // hex equivalent of newline
 mySerial.print("AT+CMGS=\"mynumber");
 mySerial.print(char(34));  // "
 mySerial.print(char(13));  // CR
 mySerial.print('\r');  // hex equivalent of newline
 mySerial.println("Moteur en marche");
 mySerial.println(char(26));  //ctrl_z
 void SMS_Arret() {
 mySerial.println("Moteur en Arret");
     while(1)
         if(mySerial.available()>0)
             Buff[BuffIndex] = mySerial.read();
             if((Buff[BuffIndex-1] == 'O') && (Buff[BuffIndex] == 'n'))
                 //Serial.print('\n');
                 //Serial.write(Buff[BuffIndex-1]);
                 //Serial.write(Buff[BuffIndex]);
                 Act=true;
                 if(Act==true)
                 SMS_Marche();
                 digitalWrite(9,LOW);
                 Act=false;
             if( (Buff[BuffIndex-2] == 'O') && (Buff[BuffIndex-1] == 'f') && (Buff[BuffIndex] == 'f'))
                 //Serial.write(Buff[BuffIndex-2]);
                 Act=false;
                 if(Act==false)
                 SMS_Arret();
                 Act=true;
             BuffIndex++;
             if(BuffIndex>250)
                 BuffIndex=5;
  delay(10);
Balwinder23
Sir i have A6 GSM module and Arduino , please send me code for auto answeing a any call
Jirik23
I have this expirience with Goouuu Tech Mini IOT-GA6 GPRS GSM Module. In all cases Im using arduino IDE Serial monitor and Arduino is connected to PC with USB
1) G6 with CP2102 module. 5V->VCC, GND->GND, RX->TX, TX->RX. PWR not conected. No problems. Module is replying to AT commands, calls and SMS are working. Notice, that as a power source Im using TTL (USB).
2) G6 with Arduino UNO. ARD-5V->VCC, ARD-GND->GND, RX->PIN2, TX->PIN3. PWR not conected. Sometimes there are problems. I think it is beacouse Im using SoftwareSerial at 115200.
3) G6 with Arduino UNO and external 2A source for G6. source-5V->VCC, source-GND->GND, RX->PIN2, TX->PIN3. PWR not conected. Communication is almost not possible beacouse of comunication errors.
4) MY FINAL SOLUTION G6 with Arduino UNO and external 2A source for BOTH. source-5V->G6-VCC->ARD-VIN, source-5V-GND->G6-GND->ARD-GND, RX->PIN2, TX->PIN3. PWR not conected. Works perfectly with almost no errors. Im not very experienced, but I thing the key is to have common GND for Arduino and G6. Not sure if its OK to have external power source and USB connected to PC. Maybe I was lucky and nothing happened.
Fuksen
I am having a set-up where the u_tx and u_rx are upperside connected to rx and tx of USB to TTL converter and using a terminal emulator programme.
Making a voice call to and from A6 vorks, ok.
Sending SMS from A6 works ok (tried via Arduino).
- Sending a mobile SMS to the A6, is received -but the output of A6 is mixed up!!! The text cannot be read and the senders number has pair vice been twistet. (eg. 45 is outputted as 54). See attached pic.
I do hope anybody can HELP?
