Topic: trouble writing PIR library (C++) (Read 1 time) previous topic - next topic
Gonzillaaa
Hello I am trying to convert the playground code for detecting presence using PIRs http://www.arduino.cc/playground/Code/PIRsense into a library so I can connect several PIRs together.
I am new to C++ but have followed a few examples. The code compiles but doesn't seem to work as expected. I get readings from two PiRs the first few times but then I only get readings from one of them (the second object initialised). I have the suspicion that objects don't work as I think in C++ and one object is overwriting variables for all, I have declared variables protected but not much luck.
all comments, suggestions much appreciated.
PIR.h
#ifndef PIR_H
#define PIR_H
#include "WProgram.h"
#include "inttypes.h"
class PIR
   public:
   PIR(int nodeId, int pinId, long pause);
   void initialise();
   void checkStatus();
   protected:
   int _nodeId;
   int _pinId;
   unsigned long lowIn;
   unsigned long start;
   unsigned long end;
   int _pause;
   bool _ready;
   bool lockLow;
   bool takeLowTime;
#endif
PIR.cpp
#include "PIR.h"
* The Parallax PIR Sensor is an easy to use digital infrared motion sensor module.
* (http://www.parallax.com/detail.asp?product_id=555-28027)
* The sensor?s output pin goes to HIGH if motion is present.
* However, even if motion is present it goes to LOW from time to time,
* which might give the impression no motion is present.
* This program deals with this issue by ignoring LOW-phases shorter than a given time,
* assuming continuous motion is present during these phases.
bool lockLow = true;
PIR::PIR(int nodeId, int pinId, long pause){
_nodeId = nodeId;
_pinId = pinId;
_pause = pause;
void PIR::initialise(){
   pinMode(_pinId, INPUT);
   digitalWrite(_pinId, LOW);
   //give the sensor some time to calibrate
   for(int i = 0; i < 30; i++){
       Serial.print(".");
   Serial.println("SENSOR ACTIVE");
   _ready = true;
void PIR::checkStatus(){
   if (_ready == true) {
       if(digitalRead(_pinId) == HIGH){
           if(lockLow){
             //makes sure we wait for a transition to LOW before any further output is made:
             lockLow = false;
             start = millis()/1000;
             delay(50);
           takeLowTime = true;
       if(digitalRead(_pinId) == LOW){
           if(takeLowTime){
                lowIn = millis();          //save the time of the transition from high to LOW
                takeLowTime = false;       //make sure this is only done at the start of a LOW phase
              //if the sensor is low for more than the given pause,
              //we assume that no more motion is going to happen
              if(!lockLow && millis() - lowIn > _pause){
                //makes sure this block of code is only executed again after
                //a new motion sequence has been detected
                lockLow = true;
                end = (millis() - _pause)/1000;
                Serial.print( _nodeId );
                Serial.print( " " );
                Serial.print( _pinId );
                Serial.print( end - start );
                Serial.println();
                delay(50);
mike_pa
Hello,
don't use the global variable lockLow, make it a class member instead, othwise this variable is not unique to each sensor!
Mike
Gonzillaaa
Thanks Mike, I tried that but the problem seems to persist. One sensor works more than one doesn't.
