This is a DNS-quiery routine for bascom.
I'm trying to write it but in C.
Some one want to work & test with me? ;D
Best Regards
Frank
Sub Udp_dns_query
Call Rtr2dest
Call Src2mymac
T_enetpackettype = &H0008 ' = &h0800
T_ip_vers_len = &H45
T_tos = &H00
T_ip_pktlen0 = &H00
T_ip_pktlen1 = &H39
T_id0 = &H48
T_id1 = &H15
T_flags = &H00
T_offset = &H00
T_ttl = &H80
'protocol (ICMP=1, TCP=6, UDP=11)
T_ip_proto = &H11
'checksum
'checksum
'IP address of source
T_ip_srcaddr0 = Myip(1)
T_ip_srcaddr1 = Myip(2)
T_ip_srcaddr2 = Myip(3)
T_ip_srcaddr3 = Myip(4)
'IP address of destination 'you have to put the IP-number of
T_ip_destaddr0 = 213 ' the DNS-server here (@HOME)
T_ip_destaddr1 = 51
T_ip_destaddr2 = 144
T_ip_destaddr3 = 37
'UDP-header
T_udp_srcport0 = &H04
T_udp_srcport1 = &H12
T_udp_destport0 = &H00 ' port &H0035 = 53 DNS
T_udp_destport1 = &H35
T_udp_len0 = &H00
T_udp_len1 = &H25
'checksum
'checksum
'DNS-query
T_udp_data = &H00 'ID
T_udp_data1 = &HB4
T_udp_data2 = &H01 'flags
T_udp_data3 = &H00
T_udp_data4 = &H00 'questions
T_udp_data5 = &H01
T_udp_data6 = &H00 'Answer RRs
T_udp_data7 = &H00
T_udp_data8 = &H00 'Authority
T_udp_data9 = &H00
T_udp_data10 = &H00 'Additional
T_udp_data11 = &H00
'queries
T_udp_data12 = &H03 'length of www
T_udp_data13 = Asc( "w")
T_udp_data14 = Asc( "w")
T_udp_data15 = Asc( "w")
T_udp_data16 = &H04 'length of home
T_udp_data17 = Asc( "h")
T_udp_data18 = Asc( "o")
T_udp_data19 = Asc( "m")
T_udp_data20 = Asc( "e")
T_udp_data21 = &H02 'length of nl
T_udp_data22 = Asc( "n")
T_udp_data23 = Asc( "l")
T_udp_data24 = &H00
'host address
T_udp_data25 = &H00
T_udp_data26 = &H01
'Class: INET
T_udp_data27 = &H00
T_udp_data28 = &H01
Call Ip_header_checksum
Call Udp_checksum
Call Echopacket
End Sub
Here
www.home.nl is used. If you want to query mail.home.nl change this
'queries
T_udp_data12 = &H04 'length of mail
T_udp_data13 = Asc( "m")
T_udp_data14 = Asc( "a")
T_udp_data15 = Asc( "i")
T_udp_data16 = Asc( "l" )
T_udp_data17 = &H04 'length of home
T_udp_data18 = Asc( "h")
T_udp_data19 = Asc( "o")
T_udp_data20 = Asc( "m")
T_udp_data21 = Asc( "e")
T_udp_data22 = &H02 'length of nl
T_udp_data23 = Asc( "n")
T_udp_data24 = Asc( "l")
T_udp_data25 = &H00
Since the UDP-message is one longer....
T_udp_len0 = &H00
T_udp_len1 = &H26
Since the total packet is one longer....
T_ip_pktlen0 = &H00
T_ip_pktlen1 = &H3A
