Topic: Arudino Lcd Shield And Stepper Help (Read 2105 times) previous topic - next topic
Trigger80
Now it works fine, BIG THANKS!!
As my prodject is gonna be , stepper,lcd shield,and distance messurment, im almost there now.
I have the lcd shield and distance messurment working in one code.
Then now i have the lcd shield and stepper in on code.
After playing around and try to add this together i find somthing strange.
When i add code for the distance messurment the stepper dont work anymore?:(
Whitout distance messurment:
Code: [Select]
oid loop() {
  int buttonVal = read_buttons();
  if(buttonVal == btnLEFT)
    digitalWrite(dir_pin, HIGH);
    digitalWrite(step_pin, LOW);
    delay(3);
    digitalWrite(step_pin, HIGH);
    delay(3);
if(buttonVal == btnRIGHT)
    digitalWrite(dir_pin, LOW);
    delay(3);
    delay(3);
this works good.
This is whit the distance code, and stops the stepper, "or bottons" so it does not work.
Code: [Select]
  long duration, distance;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance =(((duration/2)/29.4)*2) ;
    delay(3);
    delay(3);
    delay(3);
    delay(3);
Im so close to make this work as my very first prodject, any ide of whats goes wrong when i add the distance code?
Thanks
J-M-L
Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums
Pas de messages privés SVP
OldSteve
#17
Sep 11, 2016, 04:21 pm Last Edit: Sep 11, 2016, 04:24 pm by OldSteve
Code: [Select]
    delay(3);
    delay(3);
    delay(3);
    delay(3);
this works good.
Code: [Select]
    delay(3);
    delay(3);
    delay(3);
    delay(3);
Thanks
Please post all of your code, as it now stands. Edit: Not just 'loop()' It would be good to see your variable definitions, pin allocations etc.
Quote from: J-M-L
what is trigPin and echoPin?
'ping sensor'
Please do not PM me for help. I am not a personal consultant.
And others will benefit as well if you post your question publicly on the forums.
J-M-L
#18
Sep 11, 2016, 04:24 pm Last Edit: Sep 11, 2016, 04:33 pm by J-M-L
Being smart OldSteve...
Ok - I mean which pins are they connected to? what are the values of these 2 variables
--> suspecting conflict with LCD pins (and of course would be nice to know they are declared as output and input)
Analog 0   Button (select, up, right, down and left)
Digital 4   DB4
Digital 5   DB5
Digital 6   DB6
Digital 7   DB7
Digital 8   RS (Data or Signal Display Selection)
Digital 9   Enable
Digital 10   Backlit Control
should not mess with those + of course his dir_pin and step_pin, nor D0 and D1 probably for Serial.
Trigger80
Here is the complet code, if i remove the parts that is coding the distance sensor the stepper works again.
Code: [Select]
#include <LiquidCrystal.h>
LiquidCrystal LCD(8, 9, 4, 5, 6, 7);
#define step_pin 3    // Define pin 3 as the steps pin
#define dir_pin 2    // Define pin 2 as the direction pin
#define MS1 5     // Define pin 5 as "MS1"
#define MS2 4       // Define pin 4 as "MS2"
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
#define trigPin 13
#define echoPin 10
int button;
int direction;    // Variable to determine the sense of the motor
int steps = 500;      // Number of steps that you want to execute (for full steps, 200 = 1 turn)
   LCD.begin(16,2);
   LCD.setCursor(0,0);
   LCD.print("    Pall 120");
   pinMode(trigPin, OUTPUT);
   pinMode(echoPin, INPUT);
   pinMode(MS1, OUTPUT);     // Configures "MS1" as output
   pinMode(MS2, OUTPUT);     // Configures "MS2" as output
   pinMode(dir_pin, OUTPUT);    // Configures "dir_pin" as output
   pinMode(step_pin, OUTPUT);    // Configures "step_pin" as output
   pinMode(btnUP, INPUT_PULLUP);
   pinMode(btnDOWN, INPUT_PULLUP);
   digitalWrite(MS1, LOW);      // Configures the steps division (see above)
   digitalWrite(MS2, LOW);    // Configures the steps division (see above)
   digitalWrite(dir_pin, LOW);   // Sense (HIGH = anti-clockwise / LOW = clockwise) - It can be also changed
  LCD.setCursor(0,1);
  LCD.print("                ");
  LCD.setCursor(0,1);
  LCD.print(distance);
  LCD.print(" cm");
  delay(250);
    delay(3);
    delay(3);
    delay(3);
    delay(3);
int read_buttons() {
 int adc_key_in = analogRead(0);
 if (adc_key_in > 1000) return btnNONE;
 if (adc_key_in < 50)   return btnRIGHT;
 if (adc_key_in < 195)  return btnUP;
 if (adc_key_in < 380)  return btnDOWN;
 if (adc_key_in < 555)  return btnLEFT;
 if (adc_key_in < 790)  return btnSELECT;
OldSteve
J-M-L
#21
Sep 11, 2016, 04:36 pm Last Edit: Sep 11, 2016, 04:37 pm by J-M-L
Code: [Select]
#define echoPin 10
pin 10 is the Backlit Control, go for pin 11
Trigger80
all i got left is a1-a5 and tx-rx
OldSteve
#23
Sep 11, 2016, 04:44 pm Last Edit: Sep 11, 2016, 04:46 pm by OldSteve
Get rid of this for starters. what do you think it's doing?:-
Code: [Select]
Edit: It's almost 1am, so that's my last contribution for the day. Good luck. :)
Trigger80
i used the tx-rx now, but its still not working the stepper, the sensor works, and the lcd works, but not the stepper
And i did remove the pinmode.
J-M-L
Trigger80
on pin 11 i got MS1 from the easy driver
Trigger80
i have the ms1 on pin 12 now and ms2 on pin 13, and i added the right pin in the code, still nothing
so now i got pin 11 pin 10 free
Trigger80
i did mess up the code and the ms1 and ms2. now it works, but the stepper just move smal steps and realy slow::(
J-M-L
