Topic: Need Help with Bounce Library ver1.1 (Read 482 times) previous topic - next topic
Lazer57
Sep 07, 2009, 05:07 pm Last Edit: Sep 07, 2009, 05:16 pm by Lazer57 Reason: 1
Relevant code at bottom(reversed order):
I downloaded the new version and this one actually lets the code compile. I think I followed the instructions correctly judging by the example and I have looked it over many times and I don't see what I have done wrong. Any help would be great as it is crucial for this project. I have tried many different time values for bounce (from 5millis to 2 seconds, no difference).
Code chunk 2 (time setting while block):
Quote
    // CHANGES THE DEFAULT GAME TIME
    while(dip1==1){
      dip1 = digitalRead(timePin);    // read the input pin for dipswitch 1
      button1 = digitalRead(butt1Pin);   // read the input pin for button 1
      button2 = digitalRead(butt2Pin);  // read the input pin for button 2
      setTime1.update();        // updating bounce object for buttons 1 and 2
      setTime2.update();        // MOVE DIGIT is button 1, SET DIGIT is button 2
      int time1Val = setTime1.read();
      int time2Val = setTime2.read();
      if(time1Val==HIGH){
        Serial.println("BUTTON 1");
        Serial.println(time1Val);
      if(time2Val==HIGH){
        Serial.println("BUTTON 2");
        Serial.println(time2Val);
      if(dip1==0){
      disp1Metro.reset();
      disp2Metro.reset();
      if(time1Val==HIGH){
        setDigit += 1;
        if(setDigit >= 4){
          setDigit = 0;
      switch(setDigit){
        case 0:
          d2 = 0x78;
          c2 = c;
          b2 = b;
          a2 = a;
          if(time2Val==HIGH){
            d += 1;
            if(d >= 10){
              d = 0;
        case 1:
          d2 = d;
          c2 = 0x78;
          b2 = b;
          a2 = a;
          if(time2Val==HIGH){
            c += 1;
            if(c >= 10){
              c = 0;
        case 2:
          d2 = d;
          c2 = c;
          b2 = 0x78;
          a2 = a;
          if(time2Val==HIGH){
            b += 1;
            if(b >= 10){
              b = 0;
        case 3:
          d2 = d;
          c2 = c;
          b2 = b;
          a2 = 0x78;
          if(time2Val==HIGH){
            a += 1;
            if(a >= 10){
              a = 0;
      if(blinkMetro.check() == 1){
        blinkMetro.reset();
        shiftOut(dataPin, clockPin, MSBFIRST, d2);
        shiftOut(dataPin, clockPin, MSBFIRST, c2);
        shiftOut(dataPin, clockPin, MSBFIRST, b2);
        shiftOut(dataPin, clockPin, MSBFIRST, a2);
        timeDelay = millis();
      if(millis() - timeDelay >= 100){
        shiftOut(dataPin, clockPin, MSBFIRST, d);
        shiftOut(dataPin, clockPin, MSBFIRST, c);
        shiftOut(dataPin, clockPin, MSBFIRST, b);
        shiftOut(dataPin, clockPin, MSBFIRST, a);
Code chunk 1 (variables, buttons, etc):
Code: [Select]
#include <Bounce.h>
#include <Metro.h>
Metro disp1Metro = Metro(1000);
Metro disp2Metro = Metro(1000);
Metro blinkMetro = Metro(750);
long timeDelay = 0;      // variable used to hold millis() for display blinking
int dataPin = 2;                   // connect to MOSI on both displays
int clockPin =3;                   // connect to SCK on both displays
int CS1 = 4;                       // connect to CS on first display
int CS2 = 5;                       // connect to CS on second display
int butt1Pin = 7;                 // input pin for button 1
int butt2Pin = 8;                 // input pin for button 2
int button1 = 0;                   // variable to store the read value of button1
int button2 = 0;                   // variable to store the read value of button2
int dip1 = 0;                      // variable to store the read value of dipswitch1
int hold = 0;                    // holds button value
int pause = 0;                    // variable to store the read value of pause latching switch
int a = 0;      // seconds variable
int b = 0;      // tens of seconds variable
int c = 1;      // minutes variable
int d = 0;      // tens of minutes variable
int b1Array[4] = {d, c, b, a};      //number2 to be displayed on CS1
int b2Array[4] = {d, c, b, a};      //numbers to be displayed on CS2
int alarmPin = 10;                  //triggers piezo buzzer
int timePin = 12;                   // switch to set time
int pausePin = 11;                  // pauses clock
Bounce setTime1 = Bounce(butt1Pin, 100);    // instantiate bounce object for button 1
Bounce setTime2 = Bounce(butt2Pin, 100);    // instantiate bounce object for button 2
int a2 = a;      // variables used for changing default time
int b2 = b;
int c2 = c;
int d2 = d;
int setDigit = 0;    // variable for selecting what time digit to blink and thus change
