Topic: Not running sketch from the example! (Read 622 times) previous topic - next topic
sir_kimas
Not running sketch from the example! What could it be?
#include <Wire.h>
#include <Time.h>
#include <DS1307RTC.h>
  while (!Serial) ; // wait for serial
  delay(200);
  Serial.println("DS1307RTC Read Test");
  Serial.println("-------------------");
  tmElements_t tm;
  if (RTC.read(tm)) {
    Serial.print("Ok, Time = ");
    print2digits(tm.Hour);
    Serial.write(':');
    print2digits(tm.Minute);
    Serial.write(':');
    print2digits(tm.Second);
    Serial.print(", Date (D/M/Y) = ");
    Serial.print(tm.Day);
    Serial.write('/');
    Serial.print(tm.Month);
    Serial.write('/');
    Serial.print(tmYearToCalendar(tm.Year));
    if (RTC.chipPresent()) {
      Serial.println("The DS1307 is stopped.  Please run the SetTime");
      Serial.println("example to initialize the time and begin running.");
      Serial.println("DS1307 read error!  Please check the circuitry.");
    delay(9000);
void print2digits(int number) {
  if (number >= 0 && number < 10) {
    Serial.write('0');
  Serial.print(number);
Error.
Arduino\libraries\DS1307RTC\examples\ReadTest\ReadTest.ino: In function 'void loop()':
ReadTest:14: error: 'tmElements_t' was not declared in this scope
   tmElements_t tm;
ReadTest:16: error: expected primary-expression before ')' token
   if (RTC.read(tm)) {
ReadTest:18: error: expected primary-expression before '.' token
ReadTest:20: error: expected primary-expression before '.' token
ReadTest:22: error: expected primary-expression before '.' token
ReadTest:24: error: expected primary-expression before '.' token
ReadTest:26: error: expected primary-expression before '.' token
ReadTest:28: error: expected primary-expression before '.' token
ReadTest:28: error: 'tmYearToCalendar' was not declared in this scope
exit status 1
Robin2
#1
Sep 14, 2016, 03:45 pm Last Edit: Sep 14, 2016, 03:46 pm by Robin2
Please modify your post and use the code button </>
Code: [Select]
so your code looks like this and is easy to copy to a text editor. See How to use the Forum
As far as I can see your code has failed to compile. It must compile and upload before you can say whether it runs or not.
On line 16 you have unbalanced brackets. That may be the cause of all the subsequent errors.
On line 14, you may have spelled or typed tmElements_t incorrectly. Programming is case-sensitive
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
OldSteve
#2
Sep 14, 2016, 03:49 pm Last Edit: Sep 14, 2016, 04:02 pm by OldSteve
With later versions of the IDE, you need to:-
Code: [Select]
#include <TimeLib.h>not
Code: [Select]
#include <Time.h>
Edit: Aside from that, your code compiles fine for me as it is.
Please do not PM me for help. I am not a personal consultant.
And others will benefit as well if you post your question publicly on the forums.
OldSteve
I should have added, the current version of the "Time" library has been changed because of a conflict with the AVR "time.h" header. If you have an earlier version of the "Time" library, also upgrade to the current one, (which contains the "TimeLib.h" header).
INTP
Yep. Make it TimeLib.h and you'll be fine.
If you have a module with a battery, you likely don't have the right kind of battery so you'll need to modify the board a little to use normal CR2032s
OldSteve
