UK
« on: September 21, 2009, 05:52:12 pm » |
hello I am struggling with trying to finalise some code I am working on. I am using a PING sensor to trigger different midi notes depending on proximity (3 notes in total) and although the method I am using seems to work in other MIDI enabled arduino code i have used for some reason with this one I keep getting the following error message: In function 'void loop()': error: 'midiOUT' was not declared in this scope I have always used this method of midiOUT and I am stuck as to what I am doing wrong this time around. Any suggestions? /* New Variables */ int delay_time = 30; // delay for this amount each write cycle. byte channel = 1;
byte printing_byte = 0;
/* Ultrasound Sensor *------------------ * * Reads values (00014-01199) from an ultrasound sensor (3m sensor) * and writes the values to the serialport. * * http://www.xlab.se | http://www.0j0.org * copyleft 2005 Mackie for XLAB | DojoDave for DojoCorp * */
// CODE EDITED BY SEBASTIAN TOMCZAK 23 APRIL 2008 const int pingPin = 12; int val = 0; int ultrasoundValue = 0; int timecount = 0; int brightness = 0;// Echo counter int ledPin1 = 8; int ledPin2 = 9; int ledPin3 = 10; int ledPin4 = 11; int ledPin5 = 13; int whitePin = 2; const int fan = 7; int light1 = 6; int light2 = 5; int light3 = 4; int light4 = 3;
int fanState = LOW; // ledState used to set the LED long previousMillis = 0;
long interval = 5000;
int ledPin1State = LOW; // ledState used to set the LED long previousMillis1 = 10;
long interval1 = 60;
int ledPin2State = LOW; // ledState used to set the LED long previousMillis2 = 20;
long interval2 = 60;
int ledPin3State = LOW; // ledState used to set the LED long previousMillis3 = 30;
long interval3 = 80;
int ledPin4State = LOW; // ledState used to set the LED long previousMillis4 = 10;
long interval4 = 80;// LED connected to digital pin 13
void setup() { Serial.begin(31250); pinMode(ledPin1, OUTPUT); pinMode(ledPin2, OUTPUT); pinMode(ledPin3, OUTPUT); pinMode(ledPin4, OUTPUT); pinMode(ledPin5, OUTPUT); pinMode(fan, OUTPUT); pinMode(light1, OUTPUT); pinMode(light2, OUTPUT); pinMode(light4, OUTPUT); pinMode(light3, OUTPUT); pinMode(whitePin, OUTPUT); // Sets the digital pin as output
void loop() { // establish variables for duration of the ping, // and the distance result in inches and centimeters: long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds. // Give a short LOW pulse beforehand to ensure a clean HIGH pulse: pinMode(pingPin, OUTPUT); digitalWrite(pingPin, LOW); delayMicroseconds(2); digitalWrite(pingPin, HIGH); delayMicroseconds(5); digitalWrite(pingPin, LOW);
// The same pin is used to read the signal from the PING))): a HIGH // pulse whose duration is the time (in microseconds) from the sending // of the ping to the reception of its echo off of an object. pinMode(pingPin, INPUT); duration = pulseIn(pingPin, HIGH);
// convert the time into a distance inches = microsecondsToInches(duration); cm = microsecondsToCentimeters(duration);
/* Writing out values to the serial port * ------------------------------------------------------------------- */
// Append echo pulse time to ultrasoundValue if((inches >= 15) && (inches < 20)){ midiOUT(0x90, 85, 127); digitalWrite(light3, HIGH); delay(1000); digitalWrite(light3, LOW); digitalWrite(light4, HIGH); delay(3000); digitalWrite(light4, LOW); } else{ digitalWrite(light3, LOW); digitalWrite(light4, LOW); } if((inches >= 60) && (inches < 66)){ midiOUT(0x90, 85, 127); digitalWrite(light2, HIGH); delay(1000); digitalWrite(light2, LOW); } else{ digitalWrite(light2, LOW); } if((inches >= 93) && (inches < 128)){ midiOUT(0x90, 85, 127); digitalWrite(light1, HIGH); delay(1000); digitalWrite(light1, LOW); } else{ digitalWrite(light1, LOW); } // wait for a second;
if (millis() - previousMillis > interval) { // save the last time you blinked the LED previousMillis = millis();
// if the LED is off turn it on and vice-versa: if (fanState == LOW) fanState = HIGH; else fanState = LOW; // set the LED with the ledState of the variable: digitalWrite(fan, fanState); } if (millis() - previousMillis1 > interval1) { // save the last time you blinked the LED previousMillis1 = millis();
// if the LED is off turn it on and vice-versa: if (ledPin1State == LOW) ledPin1State = HIGH; else ledPin1State = LOW; // set the LED with the ledState of the variable: digitalWrite(ledPin1, ledPin1State); } if (millis() - previousMillis2 - 20 > interval2) { // save the last time you blinked the LED previousMillis2 = millis();
// if the LED is off turn it on and vice-versa: if (ledPin2State == LOW) ledPin2State = HIGH; else ledPin2State = LOW; // set the LED with the ledState of the variable: digitalWrite(ledPin2, ledPin2State); } if (millis() - previousMillis3 - 30 > interval3) { // save the last time you blinked the LED previousMillis3 = millis();
// if the LED is off turn it on and vice-versa: if (ledPin3State == LOW) ledPin3State = HIGH; else ledPin3State = LOW; // set the LED with the ledState of the variable: digitalWrite(ledPin3, ledPin3State); }
if (millis() - previousMillis4 - 10 > interval4) { // save the last time you blinked the LED previousMillis4 = millis();
// if the LED is off turn it on and vice-versa: if (ledPin4State == LOW) ledPin4State = HIGH; else ledPin4State = LOW; // set the LED with the ledState of the variable: digitalWrite(ledPin4, ledPin4State); }
/* BEGIN EDITED CODE */
void midiOUT(char command, char value1, char value2) { Serial.print(command, BYTE); Serial.print(value1, BYTE); Serial.print(value2, BYTE);}
/* END EDITED CODE */
/* Lite up LED if any value is passed by the echo pulse * ------------------------------------------------------------------- */
/* Delay of program * ------------------------------------------------------------------- */
delay(delay_time); }
long microsecondsToInches(long microseconds) { // According to Parallax's datasheet for the PING))), there are // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per // second). This gives the distance travelled by the ping, outbound // and return, so we divide by 2 to get the distance of the obstacle. // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf return microseconds / 74 / 2; }
long microsecondsToCentimeters(long microseconds) { // The speed of sound is 340 m/s or 29 microseconds per centimeter. // The ping travels out and back, so to find the distance of the // object we take half of the distance travelled. return microseconds / 29 / 2; }
« Last Edit: September 21, 2009, 05:56:31 pm by kazimier »
UK
« Reply #1 on: September 21, 2009, 05:57:10 pm » |
and here is an example of the same midiOUT method working on another code: /* * Optical Tachometer * * Uses an IR LED and IR phototransistor to implement an optical tachometer. * The IR LED is connected to pin 13 and ran continually. A status LED is connected * to pin 12. Pin 2 (interrupt 0) is connected across the IR detector. * * */ //#define DEBUG
int ledPin = 13; // IR LED connected to digital pin 13 int statusPin = 12; // LED connected to digital pin 12 int lightPin1 = 6; int lightPin2 = 9; int lightPin3 = 10; int lightPin4 = 11; int brightness = 0; int delay_time = 40; // delay for this amount each write cycle. int noteDown = LOW; byte MIDI_channel = 0; byte cc_number = 0; byte incomingByte; byte button; byte note; byte printing_byte = 0; int Value = 0; int midi_pitch = 0; int mappedrpm = 0; int state=0; #ifdef DEBUG const int DEBUG_RATE = 9600; // Serial debugging communicates at 9600 baud const int SERIAL_PORT_RATE = DEBUG_RATE; #else const int MIDI_BAUD_RATE = 31250; // MIDI communicates at 31250 baud const int SERIAL_PORT_RATE = MIDI_BAUD_RATE; #endif
volatile byte rpmcount; volatile int status;
unsigned int rpm;
unsigned long timeold;
// flag switching stuff boolean top_speed_reached = false; int on_threshold = 120; int off_threshold = 90;
void rpm_fun() { //Each rotation, this interrupt function is run twice, so take that into consideration for //calculating RPM //Update count rpmcount++;
//Toggle status LED if (status == LOW) { status = HIGH; } else { status = LOW; } digitalWrite(statusPin, status); }
void setup() { state = 0;
Serial.begin(SERIAL_PORT_RATE); //Interrupt 0 is digital pin 2, so that is where the IR detector is connected //Triggers on FALLING (change from HIGH to LOW) attachInterrupt(0, rpm_fun, FALLING);
//Turn on IR LED pinMode(ledPin, OUTPUT); digitalWrite(ledPin, HIGH);
//Use statusPin to flash along with interrupts pinMode(statusPin, OUTPUT);
rpmcount = 0; rpm = 0; timeold = 0; status = LOW;
void loop() { //Update RPM every second delay(800); //Don't process interrupts during calculations detachInterrupt(0); //Note that this would be 60*1000/(millis() - timeold)*rpmcount if the interrupt //happened once per revolution instead of twice. Other multiples could be used //for multi-bladed propellers or fans rpm = 3*1000/(millis() - timeold)*rpmcount; timeold = millis(); rpmcount = 0; attachInterrupt(0, rpm_fun, FALLING); brightness = map(rpm, 0, 50, 0, 255); analogWrite(lightPin1, brightness); printing_byte = map(rpm, 0, 50, 0, 127);{ midiOUT(0xB0, 7, printing_byte); }
if (!top_speed_reached) { if (printing_byte >= on_threshold) { top_speed_reached = true; midiOUT(0x90, 65, 127); } } else { if (printing_byte <= off_threshold) { top_speed_reached = false; midiOUT(0x90, 45, 127); } } }
//Write it out to serial port //Restart the interrupt processing
Gothenburg, Sweden
« Reply #2 on: September 21, 2009, 06:24:13 pm » |
It seems there is an end } missing at the end of the loop(), before the definition of midiOUT.
Manchester (England England)
Solder is electric glue
« Reply #3 on: September 21, 2009, 06:24:14 pm » |
Replace this:- digitalWrite(ledPin4, ledPin4State); }
void midiOUT(char command, char value1, char value2) { with this:- digitalWrite(ledPin4, ledPin4State); } }
void midiOUT(char command, char value1, char value2) { You missed a } in the loop() function and it swallowed the definition of midiOUT
« Reply #4 on: September 21, 2009, 06:26:13 pm » |
Beaten by 1 second. I know how Manchester City feel now. ;D
UK
« Reply #5 on: September 21, 2009, 06:36:41 pm » |
that is some speedy responses and of course solved the problem. It has been some long days and spotting a rogue } here and there is proving to be difficult. thanks
UK
« Reply #6 on: September 22, 2009, 05:56:08 pm » |
hello - tried the code out in situ today and there is an issue with the delay - it seems the way I have had to place the delay back into the code rather than being after serialPrint the PING sensor is not working correctly and is not getting a read out fast enough to work. Below is the way code I have at the moment: /* New Variables */ int delay_time = 10; // delay for this amount each write cycle. byte channel = 1;
// CODE EDITED BY SEBASTIAN TOMCZAK 23 APRIL 2008 const int pingPin = 12; // Ultrasound signal pin int val = 0; int ultrasoundValue = 0; int timecount = 0; int brightness = 0;// Echo counter int ledPin1 = 8; int ledPin2 = 9; int ledPin3 = 10; int ledPin4 = 11; int ledPin5 = 13; int whitePin = 2; const int fan = 7; int light1 = 6; int light2 = 5; int light3 = 4; int light4 = 3;
// Append echo pulse time to ultrasoundValue if((inches >= 15) && (inches < 20)){ midiOUT(0x90, 38, 127); digitalWrite(light3, HIGH); delay(1000); digitalWrite(light3, LOW); midiOUT(0x90, 39, 127); digitalWrite(light4, HIGH); delay(3000); digitalWrite(light4, LOW); } else{ digitalWrite(light3, LOW); digitalWrite(light4, LOW); } if((inches >= 60) && (inches < 66)){ midiOUT(0x90, 37, 127); digitalWrite(light2, HIGH); delay(1000); digitalWrite(light2, LOW); } else{ digitalWrite(light2, LOW); } if((inches >= 93) && (inches < 128)){ midiOUT(0x90, 36, 127); digitalWrite(light1, HIGH); delay(1000); digitalWrite(light1, LOW); } else{ digitalWrite(light1, LOW); } // wait for a second;
// if the LED is off turn it on and vice-versa: if (ledPin4State == LOW) ledPin4State = HIGH; else ledPin4State = LOW; // set the LED with the ledState of the variable: digitalWrite(ledPin4, ledPin4State); } delay(40); }
long microsecondsToCentimeters(long microseconds) { // The speed of sound is 340 m/s or 29 microseconds per centimeter. // The ping travels out and back, so to find the distance of the // object we take half of the distance travelled. return microseconds / 29 / 2; } as you can see the delay is now inside the code before the Serial.print, where as before I had it after the Serial.print which gave an accurate read out but meant that the midiOUT did not work. any suggestions or help would be greatly appreciated.
UK
« Reply #7 on: September 22, 2009, 05:57:07 pm » |
where as before I had it looking like this: oid midiOUT(char command, char value1, char value2) { Serial.print(command, BYTE); Serial.print(value1, BYTE); Serial.print(value2, BYTE);}
