Topic: midi error syntax issues (Read 2103 times) previous topic - next topic
kazimier
Sep 22, 2009, 12:52 am Last Edit: Sep 22, 2009, 12:56 am by kazimier Reason: 1
hello
I am struggling with trying to finalise some code I am working on. I am using a PING sensor to trigger different midi notes depending on proximity (3 notes in total) and although the method I am using seems to work in other MIDI enabled arduino code i have used for some reason with this one I keep getting the following error message:
In function 'void loop()':
error: 'midiOUT' was not declared in this scope
I have always used this method of midiOUT and I am stuck as to what I am doing wrong this time around. Any suggestions?
/* New Variables */
int delay_time = 30; // delay for this amount each write cycle.
byte channel = 1;
byte printing_byte = 0;
/* Ultrasound Sensor
* Reads values (00014-01199) from an ultrasound sensor (3m sensor)
* and writes the values to the serialport.
* http://www.xlab.se | http://www.0j0.org
* copyleft 2005 Mackie for XLAB | DojoDave for DojoCorp
// CODE EDITED BY SEBASTIAN TOMCZAK 23 APRIL 2008
const int pingPin = 12;
int val = 0;
int ultrasoundValue = 0;
int timecount = 0;
int brightness = 0;// Echo counter
int ledPin1 =  8;
int ledPin2 =  9;
int ledPin3 =  10;
int ledPin4 =  11;
int ledPin5 = 13;
int whitePin = 2;
const int fan =  7;
int light1 = 6;
int light2 = 5;
int light3 = 4;
int light4 = 3;
int fanState = LOW;             // ledState used to set the LED
long previousMillis = 0;
long interval = 5000;
int ledPin1State = LOW;             // ledState used to set the LED
long previousMillis1 = 10;
long interval1 = 60;
int ledPin2State = LOW;             // ledState used to set the LED
long previousMillis2 = 20;
long interval2 = 60;
int ledPin3State = LOW;             // ledState used to set the LED
long previousMillis3 = 30;
long interval3 = 80;
int ledPin4State = LOW;             // ledState used to set the LED
long previousMillis4 = 10;
long interval4 = 80;// LED connected to digital pin 13
 Serial.begin(31250);
 pinMode(ledPin1, OUTPUT);
 pinMode(ledPin2, OUTPUT);
 pinMode(ledPin3, OUTPUT);
 pinMode(ledPin4, OUTPUT);
 pinMode(ledPin5, OUTPUT);
 pinMode(fan, OUTPUT);
 pinMode(light1, OUTPUT);
 pinMode(light2, OUTPUT);
 pinMode(light4, OUTPUT);
 pinMode(light3, OUTPUT);
 pinMode(whitePin, OUTPUT);            // Sets the digital pin as output
 // establish variables for duration of the ping,
 // and the distance result in inches and centimeters:
 long duration, inches, cm;
 // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
 // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
 pinMode(pingPin, OUTPUT);
 digitalWrite(pingPin, LOW);
 delayMicroseconds(2);
 digitalWrite(pingPin, HIGH);
 delayMicroseconds(5);
 // The same pin is used to read the signal from the PING))): a HIGH
 // pulse whose duration is the time (in microseconds) from the sending
 // of the ping to the reception of its echo off of an object.
 pinMode(pingPin, INPUT);
 duration = pulseIn(pingPin, HIGH);
 // convert the time into a distance
 inches = microsecondsToInches(duration);
 cm = microsecondsToCentimeters(duration);
 /* Writing out values to the serial port
// Append echo pulse time to ultrasoundValue
 if((inches >= 15) && (inches < 20)){
    midiOUT(0x90, 85, 127);
   digitalWrite(light3, HIGH);
   digitalWrite(light3, LOW);
   digitalWrite(light4, HIGH);
   delay(3000);
   digitalWrite(light4, LOW);
else{
if((inches >= 60) && (inches < 66)){
   digitalWrite(light2, HIGH);
   digitalWrite(light2, LOW);
else{
 if((inches >= 93) && (inches < 128)){
   digitalWrite(light1, HIGH);
   digitalWrite(light1, LOW);
else{
              // wait for a second;
if (millis() - previousMillis > interval) {
   // save the last time you blinked the LED
   previousMillis = millis();
   // if the LED is off turn it on and vice-versa:
   if (fanState == LOW)
     fanState = HIGH;
     fanState = LOW;
   // set the LED with the ledState of the variable:
   digitalWrite(fan, fanState);
 if (millis() - previousMillis1 > interval1) {
   previousMillis1 = millis();
   if (ledPin1State == LOW)
     ledPin1State = HIGH;
     ledPin1State = LOW;
   digitalWrite(ledPin1, ledPin1State);
 if (millis() - previousMillis2 - 20 > interval2) {
   previousMillis2 = millis();
   if (ledPin2State == LOW)
     ledPin2State = HIGH;
     ledPin2State = LOW;
   digitalWrite(ledPin2, ledPin2State);
 if (millis() - previousMillis3 - 30 > interval3) {
   previousMillis3 = millis();
   if (ledPin3State == LOW)
     ledPin3State = HIGH;
     ledPin3State = LOW;
   digitalWrite(ledPin3, ledPin3State);
if (millis() - previousMillis4 - 10 > interval4) {
   previousMillis4 = millis();
   if (ledPin4State == LOW)
     ledPin4State = HIGH;
     ledPin4State = LOW;
   digitalWrite(ledPin4, ledPin4State);
 /* BEGIN EDITED CODE */
void midiOUT(char command, char value1, char value2) {
 Serial.print(command, BYTE);
 Serial.print(value1, BYTE);
 Serial.print(value2, BYTE);}
 /* END EDITED CODE */
 /* Lite up LED if any value is passed by the echo pulse
 /* Delay of program
 delay(delay_time);
long microsecondsToInches(long microseconds)
 // According to Parallax's datasheet for the PING))), there are
 // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
 // second).  This gives the distance travelled by the ping, outbound
 // and return, so we divide by 2 to get the distance of the obstacle.
 // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
 return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
 // The speed of sound is 340 m/s or 29 microseconds per centimeter.
 // The ping travels out and back, so to find the distance of the
 // object we take half of the distance travelled.
 return microseconds / 29 / 2;
kazimier
and here is an example of the same midiOUT method working on another code:
* Optical Tachometer
* Uses an IR LED and IR phototransistor to implement an optical tachometer.
* The IR LED is connected to pin 13 and ran continually. A status LED is connected
* to pin 12. Pin 2 (interrupt 0) is connected across the IR detector.
//#define DEBUG
int ledPin = 13;                // IR LED connected to digital pin 13
int statusPin = 12;  // LED connected to digital pin 12
int lightPin1 = 6;
int lightPin2 = 9;
int lightPin3 = 10;
int lightPin4 = 11;
int brightness = 0;
int delay_time = 40; // delay for this amount each write cycle.
int noteDown = LOW;
byte MIDI_channel = 0;
byte cc_number = 0;
byte incomingByte;
byte button;
byte note;
int Value = 0;
int midi_pitch = 0;
int mappedrpm = 0;
int state=0;
#ifdef DEBUG
const int DEBUG_RATE = 9600;        // Serial debugging communicates at 9600 baud
const int SERIAL_PORT_RATE = DEBUG_RATE;
#else
const int MIDI_BAUD_RATE = 31250;   // MIDI communicates at 31250 baud
const int SERIAL_PORT_RATE = MIDI_BAUD_RATE;
#endif
volatile byte rpmcount;
volatile int status;
unsigned int rpm;
unsigned long timeold;
// flag switching stuff
boolean top_speed_reached = false;
int on_threshold = 120;
int off_threshold = 90;
void rpm_fun()
 //Each rotation, this interrupt function is run twice, so take that into consideration for
 //calculating RPM
 //Update count
 rpmcount++;
 //Toggle status LED
 if (status == LOW) {
   status = HIGH;
 else {
   status = LOW;
 digitalWrite(statusPin, status);
 state = 0;
 Serial.begin(SERIAL_PORT_RATE);
 //Interrupt 0 is digital pin 2, so that is where the IR detector is connected
 //Triggers on FALLING (change from HIGH to LOW)
 attachInterrupt(0, rpm_fun, FALLING);
 //Turn on IR LED
 pinMode(ledPin, OUTPUT);
 digitalWrite(ledPin, HIGH);
 //Use statusPin to flash along with interrupts
 pinMode(statusPin, OUTPUT);
 rpmcount = 0;
 rpm = 0;
 timeold = 0;
 status = LOW;
 //Update RPM every second
 delay(800);
 //Don't process interrupts during calculations
 detachInterrupt(0);
 //Note that this would be 60*1000/(millis() - timeold)*rpmcount if the interrupt
 //happened once per revolution instead of twice. Other multiples could be used
 //for multi-bladed propellers or fans
 rpm = 3*1000/(millis() - timeold)*rpmcount;
 timeold = millis();
 rpmcount = 0;
 brightness = map(rpm, 0, 50, 0, 255);
 analogWrite(lightPin1, brightness);
 printing_byte = map(rpm, 0, 50, 0, 127);{
 midiOUT(0xB0, 7, printing_byte);
 if (!top_speed_reached) {
   if (printing_byte >= on_threshold) {
     top_speed_reached = true;
     midiOUT(0x90, 65, 127);
   if (printing_byte <= off_threshold) {
     midiOUT(0x90, 45, 127);
 //Write it out to serial port
 //Restart the interrupt processing
mlundin
It seems there is an end } missing at the end of the loop(), before the definition of midiOUT.
Grumpy_Mike
Replace this:-
with this:-
You missed a } in the loop() function and it swallowed the definition of midiOUT
Grumpy_Mike
Beaten by 1 second. I know how Manchester City feel now.  ;D
kazimier
that is some speedy responses and of course solved the problem.
It has been some long days and spotting a rogue } here and there is proving to be difficult.
thanks
kazimier
hello -
tried the code out in situ today and there is an issue with the delay - it seems the way I have had to place the delay back into the code rather than being after serialPrint the PING sensor is not working correctly and is not getting a read out fast enough to work.
Below is the way code I have at the moment:
/* New Variables */
int delay_time = 10; // delay for this amount each write cycle.
byte channel = 1;
const int pingPin = 12; // Ultrasound signal pin
int val = 0;
int timecount = 0;
int ledPin1 =  8;
int ledPin2 =  9;
int ledPin3 =  10;
int ledPin4 =  11;
int ledPin5 = 13;
int whitePin = 2;
const int fan =  7;
int light1 = 6;
int light2 = 5;
int light3 = 4;
int light4 = 3;
    midiOUT(0x90, 38, 127);
   midiOUT(0x90, 39, 127);
   delay(3000);
else{
   midiOUT(0x90, 37, 127);
else{
   midiOUT(0x90, 36, 127);
else{
     fanState = HIGH;
     fanState = LOW;
     ledPin1State = LOW;
     ledPin2State = LOW;
     ledPin3State = LOW;
     ledPin4State = LOW;
delay(40);
 /* Delay of program
as you can see the delay is now inside the code before the Serial.print, where as before I had it after the Serial.print which gave an accurate read out but meant that the midiOUT did not work.
any suggestions or help would be greatly appreciated.
kazimier
where as before I had it looking like this:
 /* Delay of program
 delay(delay_time);
