Pages: 1 ... 7 8 [9] 10 11 ... 15   Go Down
Author Topic: 3 axis auto stabilized platform  (Read 8289 times)
New Problem - but a logical one:
I think there's a bit of a problem accessing the Pulses array from the ISR, the Lib, and the sketch - is there a scope modifier I need?
Ben
The Error Says:
o: In function `incPulse':
multiple definition of `Pulses'hardware\libraries\ServoInput2\ServoInput2.o:D:\arduino-0011/hardware\libraries\ServoInput2\ServoInput2.cpp:11: first defined here
London
Have fun!
Here are some other things to look at:
in the cpp file, after #include "ServoInput2.h" add:
 #include <wiring.h>
 #include <avr/interrupt.h>
move the declarations of the following into the cpp file and make them static as follows
static volatile unsigned int Pulses[ MAX_CHANNELS + 1]; // array holding channel pulses width value in microseconds
static volatile uint8_t  Channel;      // number of channels detected so far in the frame (first channel is 1)
static volatile uint8_t State;         // this will be one of the following states:
remove the semicolon from the end of
  uint8_t ServoInput2::getState()
at the bottom of the file, make an instance of the library for the user. There can only be one instance (there is support for only a single input capture in the arduino chip) so lets make it a little easer for the user
ServoInput2 ServoInput = ServoInput2() ;
in the header file add
  #include <inttypes.h>
to the top of the header file
and add
  extern ServoInput2 ServoInput;  // make an instance for the user
to the bottom , just before the endif.
you will need to remove the following from the sketch
  ServoInput2 servoInput(); // remove this because its declared in the source file.
I think you will need to fix some inconsistent capitalization between the sketch and the source files but these changes should get you close.
« Last Edit: June 04, 2008, 01:01:46 pm by mem » Logged
Mem,
Great
That compiles. appears to run - I'll need to connect it to a receiver next.
(the creation of a user instance didn't work - but I remmed, and everything else appears ok.)
Mem,
I found the signal I want on the Receiver.
The code compiles with one exception:
This sketch line:
 uint8_t chan = 1;
        servoRoll.writeChan(chan,pulsewidth);
Yields this error:
o: In function `loop':
undefined reference to `ServoTimer2::writeChan(unsigned char, int)'
Which is quite surprising - where does "char" come from?
Here's the h:
class ServoTimer2
  public:
      // constructor:
      ServoTimer2();
      uint8_t attach(int);     // attach the given pin to the next free channel, sets pinMode, returns channel number or 0 if failure
                               // the attached servo is pulsed with the current pulse width value, (see the write method)
        void detach();
        void write(int);         // store the pulse width in microseconds (between MIN_PULSE_WIDTH and MAX_PULSE_WIDTH)for this channel
        void writeChan(uint8_t,int);     // (Channel,Pulsewidth) store the pulse width in microseconds (between MIN_PULSE_WIDTH and MAX_PULSE_WIDTH)for the
given                                     //channel
        int read();                    // returns current pulse width in microseconds for this servo
      boolean attached();      // return true if this servo is attached
 private:
       uint8_t chanIndex;      // index into the channel data for this servo
And the method code:
static void writeChan(uint8_t chan, int pulsewidth);
static void ServoTimer2::writeChan(uint8_t chan, int pulsewidth)
   // calculate and store the values for the given channel
... etc
So far you've lived up to your tagline...
Any ideas here?
Ben
London
Have fun!
The compiler is complaining because
is a static function, only accessible to code in the servoTimer2.cpp source file and not a member of the servoTimer2 class.
Making it a member method would be odd because it would allow any instance to change any other instances data. I suggest you create an array of servo instances and use that to access the data like this example sketch
#include <ServoTimer2.h>
#define NBR_SERVOS 8   // this must be between 1 and NBR_CHANNELS as defined in ServoTimer2.H
byte servoPins[NBR_SERVOS] = {2,3,4,5,6,7,8,9};  // pins our servos are attached to
ServoTimer2 Servos[NBR_SERVOS]  ;
int direction[NBR_SERVOS];   // 1 is forward, -1 is reverse
  for( int i =0; i < NBR_SERVOS; i++){
       direction[i] = 1;  //  forward
       Servos[i].attach(servoPins[i]);
       Servos[i].write( 800 + (i * 200));  // write some test data
  int pulseWidth;
    //sweep all the servos back and forth
    for( int i=0; i <  NBR_SERVOS; i++){
        pulseWidth = Servos[i].read();
        if(pulseWidth >= MAX_PULSE_WIDTH){
            direction[i] = -1;
        if (pulseWidth <= MIN_PULSE_WIDTH) {
             direction[i] = 1;
       Servos[i].write(pulseWidth + direction[i]);
    delay(10);
uint8_t is another name for an unsigned char, it's short for u(unsigned)int(integer)8(eight bits)_t(it's a type). I tend to use byte instead of uint8_t these days but either more clearly express their purpose than 'a character without a sign'. All three forms are the same to the compiler
« Last Edit: June 05, 2008, 01:50:48 am by mem » Logged
Great!
It compiles. I'll hook it up next and test some servos.
I changed uint8_t to byte universally.
one nice feature is that it supports 4 kinds of servo channels:
1. receiver-based servos
2. virtual servos (channels that get used to switch on the UAV code - or adjust software gyro gain for example) and
3. pin-tied servos - in excess of the number of channels supported by the receiver
4. non-servo peripherals - for example an ir transmitter that drives a camera based on a virtual servo.
simply assign servos to the feedback pin here (2), to nothing (0) or to some real pin
byte servoPins[NBR_SERVOS] = {2,2,2,2,0,0,8,9};  // pins our servos are attached to
More when its attached...
London
Have fun!
Good to hear your making progress, looking forward to seeing more  smiley
0 is a real Arduino pin so if you attach a servo assigned to pin 0 it will write to that pin. Pin 0 is usually used  by the serial port on the Arduino so don't actually attach an instance using pin 0 if your board has a serial interface/USB.
Your sketch could check and not call the attach method if the pin is 0 (or 1)
      if(servoPins[i] >1)
          Servos[i].attach(servoPins[i]); // this will start pulsing the pin!
      Servos[i].write( 800 + (i * 200));  // writing to an unattched pin is ok
« Last Edit: June 05, 2008, 09:27:49 am by mem » Logged
Foiled for tonight.
I have a Hitec NFS-04MG 4 channel receiver; the output stage is a 4015 shift register. The composite signal appears on one topside trace, but it appears not to be separable. (It's not a straight shot into the shift - since the reset RC timer is all tangled up in the composite line.
I think i shouldn't waste more time on this receiver - it's old school - I'd like to "crack" a receiver which is more widely available. I've got a nice GWS nano 6 chan I think I'll break open next.
In order to use this model - it might work to add a reset line on a separate pin, but that misses the point...
Ben
Mem,
I think you mentioned having a Hitec Micro O5S
 - do you think it possible to cut the composite trace and get a small wire on both the PIC input pin, and the radio signal out?
I have some other receivers - but I don't have a clearly disambiguated composite trace isolated.
that receiver is $23 at Tower hobby and quite small. It would be an excellent candidate generally...
Ben
London
Have fun!
The 05S should be suitable, you can find info on the composite signal locations in a post early in this thread. I tested the input capture code using the composit signal output from this receiver. I didn't try to inject a signal but I think you may be able to lift the pins of the SMT PIC chip if you have a small enough soldering iron. The traces are tiny so it will need a steady hand and good eyesight.
Hi to all!! Im new arduino fun, its one month i try to understand PPM/PWN and R/C transmission. I read MEM & Axeil post to know more about it, also i found an oscilloscope to investigate on my R/C Hitec Focus 4.
My idea is to create a UAV (QuadCopter) like other project on Internet ;-) but im not a good elettronic/programmer... so i follow the new post from Bgalliand as i can understand hw wants make the same goal of me.
At the moment my progress are:
1) Found the pin on receiver (Hitec Focus4) where arrived the PPM signal (4 Channel)
2) i used the old code from MEM/Axeil to read PPM without multiplex only attached to pin 8, but i can read all 4 CH without dirty and wrong order capture.
My idea is to use 4 Brushless motor to power the QuadCopter and an Accelorometer to correct the fly, perhaps the future is to have much more but at the moment is enough.
I ask for an help from where i need to move now, I can read the PPM and pulse the Brushless (with ESC controller) without other component? is need a multiplexer to have a good PPM signal?
Many thanks for your great post!!!
London
Have fun!
hi DiMiz, axileon needed the multiplexer because he wanted to use a receiver that did not output the channels in sequence. If your hitec 4 channel receiver works like my hitec 5 channel one then you can skip the multiplexer and use the recent decoder code, I think this is the latest:
 ServoInput.h
//*****************ServoInput2.h*************************************
#ifndef ServoInput2_H
#define ServoInput2_H
#define icpPin            8   // this interrupt handler must use pin 8
#define TICKS_PER_uS      2   // number of timer ticks per microsecond
#define MAX_CHANNELS    8   // maximum number of channels we can store
#define SYNC_GAP_LEN      (3000 * TICKS_PER_uS) // we assume a space at least 3000us is sync (note clock counts in 0.5 us ticks)
#define NOT_SYNCHED_state  0    // the system is not synched so the data is random
#define ACQUIRING_state  1      // one sync pulse detected but not all channels have been received
#define READY_state     2       // synched and all channel data is valid
class ServoInput2
  public:
      ServoInput2(); //Constructor
      int GetChannelPulseWidth(uint8_t);  // this is the access function for channel data
      uint8_t getState(); //State Function
 private:
#endif
servoInput.cpp
//******** servoInput.cpp *********
#include <wiring.h>
ISR(TIMER1_CAPT_vect)
   if(! bit_is_set(TCCR1B ,ICES1)){       // was falling edge detected ?
       TCNT1 = 0;               // reset the counter
       if(Channel <= MAX_CHANNELS) {
           Pulses[Channel++] = ICR1 / TICKS_PER_uS;  // store pulse length as microsoeconds
   else {                          // rising  edge was detected
        if(ICR1 >= SYNC_GAP_LEN){   // is the space between pulses big enough to be the SYNC
            Channel = 1;       // if so, reset the channel counter to 1
              if(State == NOT_SYNCHED_state)
                  State = ACQUIRING_state;        // this is the first sync pulse, we need one more to fill the channel data array
              else if( State == ACQUIRING_state)
                   State = READY_state;           // this is the second sync so flag that channel data is valid
   TCCR1B ^= _BV(ICES1);                 // toggle bit value to trigger on the other edge
ServoInput2::ServoInput2()
  pinMode(icpPin,INPUT);
  Channel = 1;
  State = NOT_SYNCHED_state;
  TCCR1A = 0x00;         // COM1A1=0, COM1A0=0 => Disconnect Pin OC1 from Timer/Counter 1 -- PWM11=0,PWM10=0 => PWM Operation disabled
  TCCR1B = 0x02;         // 16MHz clock with prescaler means TCNT1 increments every .5 uS (cs11 bit set
  TIMSK1 = _BV(ICIE1);   // enable input capture interrupt for timer 1
  return State;
int ServoInput2::GetChannelPulseWidth( uint8_t channel)
  int result;
  if( (State == READY_state)  && (channel > 0) && (channel <=  MAX_CHANNELS)  ) {
    cli();             //disable interrupts
    result =  Pulses[channel] ;
    sei();             // enable interrupts
    result = 0;        // return 0 if no valid pulse is available
  return result;
« Last Edit: June 08, 2008, 10:36:27 am by mem » Logged
Hi MEM!! Many thanks for your fast reply to my help, I try this code this evening. As i can see this is function and simple Arduino skecth, how can i use it? Also i can debug with Serial output the PulseWidth?
Many thanks i will report my test.
Sincerelly
London
Have fun!
Reply #116 has a sketch that sends the pulse width to the serial port. If you can try to post an outline of the functionality you want for your sketch,  I or others here can help you more with the code.
Thanks Mem i will try the sketch from post 116, i think is what i need now to test R/C transmission and PPM conversion.
My generic outline for what i want is:
1- Grab R/C command from transmitter
2- Receive PPM signal decode it and match Accelorometer XYZ variation to stabilized the QuadCopter
3- Pulse 4 Brushless motor using the ESC circuit (The ESc is already done :-))
At the moment if can decode without problem the PPM signal i think is great step :-)
Many thanks this evening i will report my improvements, also you never made a Helicopter like my project?
Pages: 1 ... 7 8 [9] 10 11 ... 15   Go Up
