Loading...
Pages: [1]   Go Down
Author Topic: Watching the Dog  (Read 465 times)
Summerville, Oregon
Offline Offline
Jr. Member
I like this little thing!
View Profile
Let me start by describing what I am trying to do then perhaps someone could advise me as to the best method.
The platform:
I am using an Arduino Mega
The setup:
The Mega is being used to control a 90v DC motor.  I control the speed via PWM using timer 2 and pin 10. I use the wire library to get the time of day from a DS1307, I use Serial1 to communicate with a touch screen and Serial (guess that would be 0) for debugging to the IDE and the command "attachInterrupt(0, doEncoder, CHANGE)" to keep track of the position via an optical encoder.
The mission!
I want to set up a what I used to call a watchdog timer.  I want it to make sure that a pulse from the encoder happens ever so many milli seconds. The purpose is to detect a stall condition. Something like.....
watcher code:
if( I don't hear from Mr. encoder)
     raise a fit and stop the motor;
encoder code;
    I am here and counting so sent note to watcher
Summary:
So! Any ideas folks, seems I need some combination of timer, interrupt or something.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Fair warning: the code below may not compile.
Your application has three states...
  Motor On
  Motor Off
  Motor Stalled
There are three transitions...
  Motor Off --> Motor On
  Motor On --> Motor Off
  Motor On --> Motor Stalled
I would define an enum for the states...
Code:
typedef enum ( MotorInit, MotorOff, MotorOn, MotorStalled ) tMotorState;
tMotorState CurrentMotorState;
Then in loop do something roughly like this...
Code:
void loop( void )
  switch ( CurrentMotorState )
    case MotorInit:
      // This stuff could also be done in setup
      // Ensure the pin for the motor is off
      digitalWrite( MotorPin, 0 );
      // Ensure the motor shaft is not rotating (save the state of the encoder, delay, check the state of the encoder)
      // Say hello to the human or display a fault message
      // If everything looks good, transition to MotorOff
      CurrentMotorState = MotorOff;
    case MotorOff:
      // When the conditions are right, turn the motor on
      if ( WhateverIsTrue )
        digitalWrite( MotorPin, 1 );
        CurrentMotorState = MotorOn;
    case MotorOn:
      // When the conditions are right, turn the motor off
      if ( WhateverElseIsTrue )
      // Otherwise, check for a stall
        ThisMillis = millis();
        // If the encoder changed, the motor is not stalled
        if ( EncoderChanged )
          LastEncoderMillis = ThisMillis;
        // If the encoder hasn't changed in 50ms, something is wrong
        if ( ThisMillis - LastEncoderMillis >= 50 )
          CurrentMotorState = MotorStalled;
          // Inform the human
    case MotorStalled:
      // We need the human's assitance to get out of this state
I hope that makes sense.
Logged
Summerville, Oregon
Offline Offline
Jr. Member
View Profile
Thank you for the replay CB but because of the complexity of code running I would prefer not to use a polling method.  I have found some code that looks promising but would like to see what you and the others think. I have not figured out how to enable/disable the timer interrupt call yet. help?
Keshka
Code:
#include <avr/interrupt.h>
ISR(TIMER3_OVF_vect)
    call motor power off and notify user.
void doEncoder()
    update my encoder count;
    //reset timer so it does not cause interrupt
    TCNT3 = My_beginning timer_count;
   // watch for encoder movement
   attachInterrupt(0, doEncoder, CHANGE);
    enable the ISR(TIMER3_OVF_vect) function
    move_motor()
// lots of other code to follow
// stuff
// stuff
// stuff
   stop_motor()
   disable the ISR(TIMER3_OVF_vect) function
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
I'm afraid I won't be able to help.  I don't have any low-level experience with the counters.
Logged
Summerville, Oregon
Offline Offline
Jr. Member
View Profile
Any one used timer3 on the Mega?
Keshka
Logged
Summerville, Oregon
Offline Offline
Jr. Member
View Profile
OK, when all else fails read the book and do it yourself.  I modified Timer1 created by Jesse Tane and created Timer3.  You can find my notes and the files here: http://www.arduino.cc/playground/Code/Timer1
Keshka
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Thank you for following-up and thank you for publishing the fruits of your labor!
Logged
Pages: [1]   Go Up
Print
Jump to:
