Topic: Watching the Dog (Read 2059 times) previous topic - next topic
Keshka
Let me start by describing what I am trying to do then perhaps someone could advise me as to the best method.
The platform:
I am using an Arduino Mega
The setup:
The Mega is being used to control a 90v DC motor.  I control the speed via PWM using timer 2 and pin 10. I use the wire library to get the time of day from a DS1307, I use Serial1 to communicate with a touch screen and Serial (guess that would be 0) for debugging to the IDE and the command "attachInterrupt(0, doEncoder, CHANGE)" to keep track of the position via an optical encoder.
The mission!
I want to set up a what I used to call a watchdog timer.  I want it to make sure that a pulse from the encoder happens ever so many milli seconds. The purpose is to detect a stall condition. Something like.....
watcher code:
if( I don't hear from Mr. encoder)
    raise a fit and stop the motor;
encoder code;
   I am here and counting so sent note to watcher
Summary:
So! Any ideas folks, seems I need some combination of timer, interrupt or something.
Coding Badly
Fair warning: the code below may not compile.
Your application has three states...
 Motor On
 Motor Off
 Motor Stalled
There are three transitions...
 Motor Off --> Motor On
 Motor On --> Motor Off
 Motor On --> Motor Stalled
I would define an enum for the states...
typedef enum ( MotorInit, MotorOff, MotorOn, MotorStalled ) tMotorState;
tMotorState CurrentMotorState;
Then in loop do something roughly like this...
void loop( void )
 switch ( CurrentMotorState )
   case MotorInit:
     // This stuff could also be done in setup
     // Ensure the pin for the motor is off
     digitalWrite( MotorPin, 0 );
     // Ensure the motor shaft is not rotating (save the state of the encoder, delay, check the state of the encoder)
     // Say hello to the human or display a fault message
     // If everything looks good, transition to MotorOff
     CurrentMotorState = MotorOff;
     break;
   case MotorOff:
     // When the conditions are right, turn the motor on
     if ( WhateverIsTrue )
       digitalWrite( MotorPin, 1 );
       CurrentMotorState = MotorOn;
     break;
   case MotorOn:
     // When the conditions are right, turn the motor off
     if ( WhateverElseIsTrue )
     // Otherwise, check for a stall
       ThisMillis = millis();
       // If the encoder changed, the motor is not stalled
       if ( EncoderChanged )
         LastEncoderMillis = ThisMillis;
       // If the encoder hasn't changed in 50ms, something is wrong
       if ( ThisMillis - LastEncoderMillis >= 50 )
         CurrentMotorState = MotorStalled;
         // Inform the human
     break;
   case MotorStalled:
     // We need the human's assitance to get out of this state
     break;
I hope that makes sense.
Keshka
Thank you for the replay CB but because of the complexity of code running I would prefer not to use a polling method.  I have found some code that looks promising but would like to see what you and the others think. I have not figured out how to enable/disable the timer interrupt call yet. help?
Keshka
#include <avr/interrupt.h>
ISR(TIMER3_OVF_vect)
   call motor power off and notify user.
void doEncoder()
   update my encoder count;
   //reset timer so it does not cause interrupt
   TCNT3 = My_beginning timer_count;
  // watch for encoder movement
  attachInterrupt(0, doEncoder, CHANGE);
   enable the ISR(TIMER3_OVF_vect) function
   move_motor()
// lots of other code to follow
// stuff
// stuff
// stuff
  stop_motor()
  disable the ISR(TIMER3_OVF_vect) function
Coding Badly
I'm afraid I won't be able to help.  I don't have any low-level experience with the counters.
Keshka
Any one used timer3 on the Mega?
Keshka
Keshka
OK, when all else fails read the book and do it yourself.  I modified Timer1 created by Jesse Tane and created Timer3.  You can find my notes and the files here: http://www.arduino.cc/playground/Code/Timer1
Keshka
Coding Badly
Thank you for following-up and thank you for publishing the fruits of your labor!
