Loading...
Pages: [1]   Go Down
Author Topic: bonehead about servo sweep  running ard 0017  (Read 210 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Am trying to learn programming.  Have seen what others are doing and came up with this adaptation to move a bot and avoid objects.  I would like to sweep the head or "scan", and have come close but no cigar.  This code sweeps the head but very fast one way and slow the other; so only steps by 1, in one direction.  It only reads the sensor at the end of the sweep.  If I remove the scan code the bot works fine with the sensor looking ahead only and sees walls, etc.  What am I not seeing?  Thanks much, this is a great site.
Code:
   #include <Servo.h>
Servo left;
Servo right;
Servo head;
int pos = 0;
int headPos = 0;
int value = 0;
int treshold = 150;
int sensor = 0;
  Serial.begin  (9600);
  right.attach(10);
  left.attach(9);
  head.attach(6);
void ReadSensor () {
  for(headPos = 0; headPos <180; headPos += 1)
    head.write(pos);
    delay(10);
  for(headPos = 180; headPos >= 1; headPos-=1)
    head.write(headPos);
    delay(10);
  value = analogRead(0);
  Serial.println(value);
  if (value > treshold) {
    turn();
    move();
void turn () {
  left.write(145);
  right.write(145);
void move () {
  left.write(135);
  right.write(45);
  ReadSensor();
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
    head.write(pos);
    delay(10);
    delay(10);
I'd say that you're probably missing some "}" braces in there.
Or they're misplaced, which is more likely if this code is compiling
Code:
  for(headPos = 0; headPos <180; headPos += 1)  {
        head.write(pos);
        delay(10);
       // You may want to do stuff here
  for(headPos = 180; headPos >= 1; headPos-=1) {
      delay(10);
         turn();
         move();
« Last Edit: October 17, 2009, 04:50:23 pm by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks AWOL, think you are right.  I have played with moving the braces around and every iteration that will compile (quite a few) also acts differently.  Guess I have to find the right combo.  Thanks again.
Logged
Pages: [1]   Go Up
Print
Jump to:
