Author Topic: Take action based on string  (Read 251 times)
Looking for some help, but don't really know what it's called, so not sure how to search for it!
OK so I get sent a string, say "ABCFL"
For each item in the string, I want to take a unique action. For each possible string value, I've got a function that changes the state of a number of digital pins.
Is there anyway to call a function based on a character without looking through every possible value using if & ifelse statements?
Is there a way to like, put multiple commands into an array? Like could I somehow put
digitalWrite(13,HIGH);
digitalWrite(12,HIGH);
delay(100);
digitalWrite(13,LOW);
digitalWrite(12,LOW);
into an array at position 48, so that if the character in the position of the string I am looking at was "0", I could use 0 as a value to look up the sequence in the array, it would perform that sequence of lines?
Obviously I can write a function that wraps those lines up into a small function.
The only way I can think to do it is to write a big, long in-elligant function that says
if(string_value=='0'){
zero();
elseif(string_value=='A'){
a();
elseif(string_value=='B'){
b();
I'm obviously no programmer, and this is badly explained, so thanks for your help.
Alex
here is a short exampe:
// array of pointer to function
void (*funcArr[3])() = {NULL};
  // fill array with function pointers
   funcArr[0] = &a;
   funcArr[1] = &b;
   funcArr[2] = &c;
  // this string contains the characters
  char string_value[10];
  // scan all characters in the string
  // call a() for 'a', b() for 'b' and so on
  for (int i=0; i<10; i++) {
    int index = string_value[i]-'a';
    // only 'a'..'c' is allowed
    if (index > 0 && index < 3)
      (*funcArr[index])();
// here are the functions to call
void a()
void b()
void c()
Mike
Awesome!
Thanks heaps - will try to digest now...
