Topic: Arduino + Servo (Read 494 times) previous topic - next topic
GuzzVJ
Hi, my name is Guzz and i'm new on the arduino world. I'm having some trouble to write a code to control 4 servos with a arduino, and i dont know what can be wrong with my code, i'm not a programmer (yet). I wrote this code based on de sweep code from the arduino examples. ''The code compiles fine, but when i try to upload to the board it crashes. Im using the arduino duemilanove with atmega 328." - solved -  The code is like this...
Code: [Select]
#include <Servo.h>
Servo myservo0;  // create servo object to control a servo
              // a maximum of eight servo objects can be created
int pos0 = 0;    // variable to store the servo position
Servo myservo1;  // create servo object to control a servo
int pos1 = 0;    // variable to store the servo position
Servo myservo2;  // create servo object to control a servo
int pos2 = 0;    // variable to store the servo position
Servo myservo3;  // create servo object to control a servo
int pos3 = 0;    // variable to store the servo position
myservo0.attach(9);  // attaches the servo on pin 9 to the servo object
myservo1.attach(8);  // attaches the servo on pin 8 to the servo object
myservo2.attach(7);  // attaches the servo on pin 7 to the servo object
myservo3.attach(5);  // attaches the servo on pin 5 to the servo object
for(pos0 = 0; pos0 < 180; pos0 += 1)  // goes from 0 degrees to 180 degrees
{                                  // in steps of 1 degree
  myservo0.write(pos0);              // tell servo to go to position in variable 'pos'
  delay(5);                       // waits 15ms for the servo to reach the position
for(pos0 = 180; pos0>=1; pos0-=1)     // goes from 180 degrees to 0 degrees
for(pos1 = 0; pos1 < 180; pos1 += 1)  // goes from 0 degrees to 180 degrees
  myservo1.write(pos1);              // tell servo to go to position in variable 'pos'
for(pos1 = 180; pos1>=1; pos1-=1)     // goes from 180 degrees to 0 degrees
for(pos2 = 0; pos2 < 180; pos2 += 1)  // goes from 0 degrees to 180 degrees
  myservo2.write(pos2);              // tell servo to go to position in variable 'pos'
for(pos2 = 180; pos2>=1; pos2-=1)     // goes from 180 degrees to 0 degrees
  myservo2.write(pos0);              // tell servo to go to position in variable 'pos'
for(pos3 = 0; pos3 < 180; pos3 += 1)  // goes from 0 degrees to 180 degrees
  myservo3.write(pos3);              // tell servo to go to position in variable 'pos'
for(pos3 = 180; pos3>=1; pos3-=1)     // goes from 180 degrees to 0 degrees
This code is working fine, but is not doing what i wanted. Each one of the servos moves one at a time, how could i make them move at the same time?
AWOL gave me some help and rewrote this sketch for me to simplify it,
Code: [Select]
#include <Servo.h>
Servo myservo [4];  // create servo object to control four servos
int pos [4] = 0;    // variable to store the servo position
 myservo[0].attach(9);  // attaches the servo on pin 9 to a servo object
 myservo[1].attach(8);  // attaches the servo on pin 8 to a servo object
 myservo[2].attach(7);  // attaches the servo on pin 7 to a servo object
 myservo[3].attach(5);  // attaches the servo on pin 5 to a servo object
 for (int i = 0; i < 4; ++i) {
     for(pos[i] = 0; pos[i] < 180; pos[i] += 1)
      myservo[i].write(pos[i]);
      delay(5);                       // waits 5ms for the servo to reach the position
   for(pos[i] = 180; pos[i]>=1; pos[i]-=1)     // goes from 180 degrees to 0 degrees
      myservo[i].write(pos[i]);              // tell servo to go to position in variable 'pos'
but when i try to compile it i get the message
error: array must be initialized with a brace-enclosed initializer
in the [glow]int pos [4] = 0;[/glow] line
Can someone tell me how can i fix this?
Thanks AWOL for all your help :)
and thanks everybody
PaulS
int pos[4] = {0, 0, 0, 0};
Grumpy_Mike
#2
Nov 11, 2009, 08:20 pm Last Edit: Nov 11, 2009, 08:22 pm by Grumpy_Mike Reason: 1
Guzz, please can you remove your duplicate posts.
AWOL
#3
Nov 11, 2009, 08:58 pm Last Edit: Nov 11, 2009, 09:33 pm by AWOL Reason: 1
Oops!
Code: [Select]
int pos[4] = {0};
Two things here:
The initialisation isn't necessary because:
a) it's done at the start of the for loops anyway.
b) the values are reset to zero when the program is started, but only because of their global scope.
Quote
Turn the example inside out:
Code: [Select]
for(int pos = 0; pos < 180; pos += 1) {
        myservo[i].write(pos);
        delay(5);
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
