Topic: Using the watchdog to wake up from sleep (Read 10782 times) previous topic - next topic
DAGO
Hey, I'm trying to make a timer thingie that basically just displays the elapsed time on an LCD. I want to put the CPU to sleep every second (or every 500ms) and just wake up from sleep to refresh the LCD with the current time (need to have timer0 running so I can't do a full power-down, just power-save afaik). The documentation on the watchdog and sleep seem surprisingly sparce and I'm having trouble setting it up. Currently I'm doing something like this (just showing the bits related to sleep and watchdog):
Code: [Select]
#include <avr/wdt.h>
#include <avr/sleep.h>
#include <avr/interrupt.h>
 MCUSR = 0;
 wdt_disable();  // disable watchdog on boot
 set_sleep_mode(SLEEP_MODE_PWR_SAVE);    // set sleep mode
 // set other stuff
 sei();          // disable interrupts after waking up from sleep
 wdt_disable();  // disable watchdog when running
 // do stuff
 wdt_enable(WDTO_500MS);    // enable watchdog
 cli();                     // enable interrupts
 sleep_mode();              // go to sleep
ISR(WDT_vect) {  // go back to the main loop when we get an interrupt from the watchdog timer
 loop();
But it is not working. Seems like the processor just goes to an infinite watchdog reset loop (very hard to reprogram the chip when its in the loop, you have to reset the chip exactly at the right time so it will get programmed). How do I just simply execute the loop(); every one or every half second and keep the cpu in power-save mode for the rest of the time?
wayoda
the standard settimg for the atmega is to do a System-reset when the watchdog times out. If you want to you IRS-metghod to be called instead you have to set some bits  in Register : WDTCSR
I think you should download the Datasheet for the ATMega168 and read chapter 10.9.2. to find out which setting would be correct.
Eberhard
DAGO
#2
Nov 14, 2009, 08:27 pm Last Edit: Nov 14, 2009, 09:34 pm by Dago Reason: 1
Code: [Select]
 MCUSR = 0;
 // set other stuff
 // do stuff
 WDTCSR = 0x55;
 MCUSR = 0;
 wdt_reset();
 cli();
 sleep_mode();
 loop();
I changed it to this and now it does not reset but it just goes to sleep and never wakes up. Never enters the ISR(WDT_vect) function.
Edit: Whoops, sei() and cli() the wrong way. After swapping them the CPU does wake up but quite uhh intermittently and randomly and then stop waking up completely after a while.
Also, it seems timer0 (from which the millis() function gets its time and therefore the DateTime library that I'm using) is not running in power-save mode. It afaik SHOULD be running in idle mode but something weird happens in idle, the time jumps around for hours or days at a time and goes backwards etc., dunno why is that...
mitch_79
#3
Nov 15, 2009, 01:34 am Last Edit: Nov 15, 2009, 01:41 am by mitch_79 Reason: 1
I can't really describe in detail why, but this strikes me as something that should cause a problem...
Code: [Select]
 loop(); // <- I think this disrupts your expected program flow
It is unnecessary at the least.  From the atmega Datasheet: "If an enabled interrupt occurs while the MCU is in a sleep mode, the MCU wakes up. The MCU
is then halted for four cycles in addition to the start-up time, executes the interrupt routine, and
resumes execution from the instruction following SLEEP."
[Edit:  I think I need to look at sleep.h]
mitch_79
So... while I was studying, I accidentally wrote some evil code...
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1258251558/0
In other variants of my test code, I've been having trouble getting the watchdog timer to Interrupt at anything less than a few milliseconds.
with...
WDTCSR = B01010111;
ISR(WDT_vect) gets called constantly.  According to the datasheet I should expect 2.0s between interrupts but that does not appear to be the case.
I don't mean to hijack your thread Dago, but if we understand this I think we could then solve your application.
mitch_79
Ok, I think I have it...
The datasheet is a little vague, but between the example and the content it has become clear that setting WDTCSR is a two step procedure.
First, set WDTCSR = B00011000.  This enables Watchdog Changes (I'm not sure why bit3 WDE: Watchdog System Reset Enable also must be set but it doesn't work otherwise).
Second, set WDTCSR WDPn bits to set prescaler.
Here is some code that is working on my 1280.  Note: I couldn't figure out how to use wdt_enable(value) in wdt.h so I wrote myWatchdogEnable().
Code: [Select]
ISR(WDT_vect) {
 cli();
 wdt_disable();
 mySerial.println("wakeup!");
 sei();
 mySerial.begin(115200);
 delay(500);  // stay awake for 0.5 seconds
 wdt_reset();
 myWatchdogEnable();
 mySerial.println("...going to sleep.");
 delay(100);
 sleep_mode();
void myWatchdogEnable() {  // turn on watchdog timer; interrupt mode every 2.0s
 cli();
 MCUSR = 0;
 WDTCSR |= B00011000;
 WDTCSR = B01000111;
 sei();
Odisej
If you are looking to make a low-consumption arduino clock I recomend buying a RealTimeClock (RTC) chip and just use full shutdown. Works for me :)
