Topic: Counter for hardware with Arduino due to use an encoder (Read 576 times) previous topic - next topic
I just made a pulse counter for hardware by  arduino one. But I need to do with the arduino due. Because the account is greater than 70000 pulses im in need to do so with arduino due. I found very little information about this
I even read 36. Timer Counter (TC) SAM3X data sheet, but not if you go down the right path.
could you help me
unsigned long pulses;
              TC_Configure ( TC0, 0, TC_CMR_TCCLKS_XC2| TC_CMR_ETRGEDG_FALLING | TC_CMR_ABETRG | TC_CMR_LDRA_FALLING ); //tratar deactivar la escritura con WAVE
            const uint32_t pulses = TC_ReadCV ( TC2, 2 );
            //Serial.print( TC_ReadCV(TC0,0));
            Serial.print( REG_TC0_CV0, DEC);
            Serial.print(" ");
Hi there @Gabriel_MX
You can do what you want with library tc_lib (https://github.com/antodom/tc_lib). Have a look to example capture_test.ino, it gives you the instantaneous duty and period of a digital signal. In your problem the signal would be coming from your encoder. The period given would be the duration of an encoder tick, so 1/period will give you the velocity in ticks per second.
I hope it helps.
